AI 200cc Start Up/ABS INOP Light
Old 07-08-2009, 11:11 PM
Elliott's94Z's Avatar
Default AI 200cc Start Up/ABS INOP Light
The AI set up is complete. After the start up the "ABS INOP" light came on. Checked for codes, none..never once messed with the ABS during install, all fuses are in perfect shape. Any ideas??
BIG Thumbs up to Ron and Phil at AI This thing flat out MOVES! It has a partial tune as it sits right now. Awaiting the dyno tune still. Hope by next week or so. I also put in a Yank SS3600 stall...if you have a A4 get one! Enough said
Thanks to Cody at Rockin-C- Racing for the help with the build, Kevin at My Machine Head for coming through last minute on the bad *** Alternator Relocate bracket "Which looks sweet! Thanks to AI for the most beautiful heads and camshaft I've ever seen... And Dave at Yank Performance for the hook up!
P.S. Will post up pics of the build and dyno #'s here soon!
Old 07-08-2009, 11:18 PM
GoFastKid's Avatar
Sounds like you have yourself one hell of a ride man..look forward to seeing video and pics
Old 07-08-2009, 11:20 PM
za355tx's Avatar
I'm glad you got the car running again. I can't wait to see what kind of numbers that car puts down. Give us a taste of the cam size man I'm interested. Good luck.
Old 07-08-2009, 11:26 PM
sdotlog's Avatar
nice dude. It just seems like im copying your set up lol. I've been looking at that AI site alot. I just got the LE stuff, but I'll give it some time. Congrats on getting that car running again.
Old 07-08-2009, 11:51 PM
ROWDYZ28's Avatar
Awesome bro! I cant wait to see it at your house this weekend. Stacie and I will be in Portland around 4-5 on Friday. Talk soon and congrads!!!
Old 07-08-2009, 11:53 PM
BruceBufferTA's Avatar
+2
Old 07-09-2009, 12:05 AM
Moderator
BizZzatch350's Avatar
Congrats on the car, did you do long tubes at the same time? Go snoop around the bottom of the engine bay on the sides of the shock towers, very well may have melted a plug/harness to the wheel hubs. We had to some what move mine around when we did LTs.
Old 07-09-2009, 02:00 AM
marc97taws6's Avatar
I want to hear this new beast and some track times.. Wish I didn't have to default my dream car for 4 years
Old 07-09-2009, 04:45 AM
RamAir95TA's Avatar
Welcome to the AI club. You won't be disappointed!
Old 07-09-2009, 06:33 AM
Village Troll
SS RRR's Avatar
Best of luck on your new heads/cam endeavor, friend!
Since there was a lot of traffic around your ABS block start looking at connectors and following wires to sensors.
Old 07-09-2009, 07:21 AM
dlk1950's Avatar
I'M jealous....Best of luck with setup. Waiting on dyno #s and video.
Old 07-09-2009, 07:42 AM
Whyrun's Avatar
Congrats on your build, It's always good when a plan come's together
Old 07-09-2009, 09:07 AM
Tireburnin's Avatar
Most common reason for the ABS light is burning/breaking or disconnecting the plug on the passenger shock tower down by the header primary. ABS cods show up in a different way and can only be read by a Tech 2 and the codes start with a C. If you have a 3 channel ABS setup (non traction control) you just have to check the plug in the rear end (make sure it's plugged in and you can pull the sensor and clean it). Then there are two wheel sensors one on each front wheel that have plugs that should be checked for clean connections).
Good luck with your ABS light, try pulling the wires up from the passenger shock tower and checking they aren't burned or knicked first. Glad to hear you're happy with the new setup.
Old 07-09-2009, 10:28 AM
I will look into the ABS suggestions..thanks guys!
Track times, pictures and dyno #'s soon to follow
Old 07-09-2009, 10:31 AM
airfix's Avatar
Whats your set up elliott? Did u end up going with a stroker?
Old 07-09-2009, 01:50 PM
AChotrod's Avatar
Sweet deal!!! Cant wait to hear and see the vids, track numbers and dyno! With sticky tires it should fly!!
Old 07-09-2009, 09:53 PM
99Ls1fever's Avatar
Awesome H/C Setup, what numbers are you hoping to put down? Also, what is the specs on your cam?
Old 07-09-2009, 10:02 PM
robsquikz28's Avatar
very nice setup man and im glad ur happy
Old 07-09-2009, 10:14 PM
BLK,97,T/A,M-6's Avatar
Nice set-up, I bet you'll run in the 11.90-12.10 @ 116 to 118 range.
Old 07-09-2009, 10:36 PM
SPEEDYTRANSAM1996's Avatar
Man i bet that thing sounds sweet im going to get them heads one day. Post that video bro i gotta hear it, I mean "WE"
Quick Reply: AI 200cc Start Up/ABS INOP Light
