Old 05-26-2016, 04:29 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
Fuel Pump Replacement
Old 07-11-2009, 12:39 PM
DopdBrd's Avatar
Default Fuel Pump Replacement
Just wondering, how much would a GM dealership or mechanic shop, charge to replace the fuel pump in a LT1 THE RIGHT WAY.
Thinking about buying a 96Z for a DD that needs a fuel pump, might use the fuel pump issue to talk him down.
Thanks
Old 07-11-2009, 12:44 PM
RamAir95TA's Avatar
Thanks
This solely depends on your version of "THE RIGHT WAY." If the right way to you is dropping the tank, expect to pay $700+ from a reputable shop.
If the "RIGHT WAY" to you is to cut a hatch (which is the right way to me ), you'll pay for the cost of the pump and that's it.
Here is a finished install I did for a friend.
Old 07-11-2009, 01:12 PM
Wooshie's Avatar
THIS is the right way to do it.
Old 07-11-2009, 02:08 PM
AChotrod's Avatar
I thought that was the only way!!! I would not waste the time dropping the tank.
Old 07-11-2009, 04:26 PM
DopdBrd's Avatar
I have cut an access door in my old car and will do the same in the new car.
The right way, per GM, is to drop the rear end and the tank. I figured it would be around 1000 to do it. Gonna use that to try and talk the guy down on this Camaro. Then if I do buy it will will cut an access door in it.
Old 07-11-2009, 04:28 PM
RamAir95TA's Avatar
Ahhh, nice plan.
Old 07-11-2009, 05:48 PM
JB_97ws6TA's Avatar
When I changed mine for some reason I thought cutting a hole in the car was a bad thing so i dropped the tank. I got about half way through then decided that I would rather cut 15 holes in the floor than ever think about doing it GM's way again. PITA
Old 07-11-2009, 09:35 PM
killagt's Avatar
what you guy using when cutting the hole ? thanks
Old 07-11-2009, 09:47 PM
WYATT318MOPAR's Avatar
air cut off wheel worked good for me, on several occasions
Old 07-11-2009, 10:25 PM
RamAir95TA's Avatar
Cutoff wheel, Dremel, tin snips, etc.
Old 07-11-2009, 11:14 PM
McCauleyWB's Avatar
I hadn't ever run in to the problem, and didn't think of the access hatch, so I dropped the rear when having to replace the pump for the first time. Never again. I think I'll go ahead and cut everything for any future problems, but I have a couple of questions: How much room is there underneath until hitting something? What dimensions should the cutout be and is it centered?
Old 07-11-2009, 11:26 PM
RamAir95TA's Avatar
Just get close to the picture. It's not an exact science. There isn't much room under the floor, so be careful.
Old 07-11-2009, 11:43 PM
shbox's Avatar
That price would probably not be far off.
Old 07-12-2009, 01:10 AM
SPEEDYTRANSAM1996's Avatar
thats the way my brother did mine..........
Old 07-12-2009, 04:43 AM
mj114679's Avatar
can someone PM me a write up on cutting out the floor to replace the fuel pump. PLEASE PM it to me
Thanks guys
Old 07-12-2009, 08:19 AM
RamAir95TA's Avatar
Thanks guys
Just look at the picture and cut. That's all.
Old 07-12-2009, 11:57 AM
the_merv's Avatar
No, that's the half-assed way to do it. Here's the right way..
For those of you that have done this you know why.
Pretty much judge the pics by the machined grooves in the body. You have about 1" of clearance in most places.
Thanks guys
Roll back the carpet, cut.
Old 07-12-2009, 12:19 PM
DopdBrd's Avatar
At first I was like, , then I thought about it and was like
That is for sure the right way to do it.
Old 07-12-2009, 12:43 PM
the_merv's Avatar
Lol..it just jumps out at you when you see it. Kinda like the hidden ninja in that pic.
Old 07-12-2009, 01:38 PM
DopdBrd's Avatar
Hidden Ninja!!????? OH SNAP!
Quick Reply: Fuel Pump Replacement
