2 coolant system questions
1st off i have a set of AFR 227's on my 383 i bought already built. The drivers side head has a empty hole for a sensor towards the front of the head behind the first primary. the pass side head already has a sensor toward the back of the head im guessing it's the coolant temp sensor. what is the one on the driver side for?
secondly when i got the motor it had both coolant holes in the back of the head plugged instead of the stock crossover setup. do i need the crossover? if so i do i go about re routing it? crossover then a line to the radiator off of it.
The passenger side hole was meant for a fan switch. It heats up completes a ground, viola, fans on. It is a TPI used method.
The driver side is the dedicated side for the coolant temp sender. (gauges not ECM)
Last, I recommend the cross over.
also checked on the crossover going to pick one up from the dealer soon.
Thanks man big help
I also suspect your steam vent tubing is routed differently too. Mine runs down the passenger side of the intake then makes a 90 degree turn and goes into the lower TB hose bib.
Jake
West Point ROCKS!
wow so Im an idiot and also just realized i Fu*ked up.
I stood a griffen radiator vertical and welded an fittings to my water pump and did my coolant system is braided line and AN fittings. I ran the thermostat housing to the top of the radiator and the right side outlet to the bottom of the radiator
