Anyone running a 218/230/114 lsa have an idle clip?
Just wondering, why you were going with such a small cam? I know someone with a cam very close to those specs in a 383, u dont even know its cammed. Peak hp ~5k and Peak Tq ~3k(no powerband) and its about .4-.6 slower than a barely bolt on car. In no way am i trying to put you down. Just giving some food for thought.
How can it be slower than a bolt on car, it's still more aggressive than a stock cam or even hot cam (not that that's saying much)?
That is going to sound stock.
You could go with a 112-3LSA and with good tuning still have it sound stock but not be so compromised.
I am guessing emissions testing is what is prompting the rediculously wide LSA???
I don't think we have run into eachother yet. If you want I can shoot you a PM when I am coming down to GLD always good to see a few quick LT1 cars together. Someone local wants to test out his new AI topend on his 383.
Its clearly a blower/nitrous cam with the very wide exhaust favored split and 114 LSA.
It won't be much on motor, especially in a 383. Numbers at .050 don't mean much in the big picture, but it has negative overlap @ .050...
http://www.youtube.com/watch?v=Q-KnTCCWIXk
This is mine. 220/230 .544 .544 114 LSA
Is that close enough?
Roxy, I reccomend I custom Joe O cam, designed specifically for your needs and will outperform any other cam in the universe
It won't bleed off any boost at least, thats for sure.
Joe may or may not be the best to ask that question of but he would be better than what has been posted sofar. As I said, just so much bad info out there. It pretty much invariably leads people astray when trying to spec their own cam. People only post half the info generalizations like "wider LSA makes for a wider powerband" ignoring any effort to post where "wider" is in reference too was it based on a 106 starting point or a 114.
I know enough to say "I don't know" and call someone I trust that does.
I have never done any business with Joe and honestly don't ever intend too BUT that said he is clearly above average on his understanding of LT1 performance so I would put faioth in him before a lot of the bigger vendors people trust.
Here is what I know about it. The 214/224 blower cam that comp sells is tough to beat on most cars unless you want to get some more rpm out of it. It drives absolutely great. You wont hear it, but do you need to? Performance is performance regardless of what it sounds like.
i would get ur info together on ur engine build and contact several people that grind cams and get there feed back on ur info check their numbers they give u against the cam u have selected and do some thinking. think twice buy once!
Well, this thread turned out interesting...
I didn't really want cam advice so much, I just wanted to hear what the cam sounded like.
Like I said I don't want a lot of cam surge. I want a near stockish sound, maybe a slight chop but no lope. That's it.
That said I will probably go with a custom grind.
You might know Ron(juicedimpss on a couple forums), guy who had a 96 Impala for awhile? He had a Lingenfelter 211/219 112 cam in his car and with a raised idle it sounded stock performed wonderfully too.
That said folks worry about choppy idle and surge a bit too much, you can have a pretty big cam before those things become real issues IF the cam is spec'd responsibly and the car tuned well.
Lots of cars sound nasty either because the owner wanted the sound and kept the idle low or because of bad tuning.
With 4.10s and a 383 you should be able to go up into the 230s on a 112lsa before surge is an issue.
I was joking...Joe has not done cams in years.
If I was you I would contact bullet cams and give them the info they ask for and use the cam they send you. No need to BS it.....they put out WAYYwayy more fast cars than some of the other places. I would trust them to do what you need.
