pushrods?
Old 07-18-2009, 03:37 PM
jasonz28camaro's Avatar
Default pushrods?
im putting in a cc306 with 1.6 mags and double springs. i just want to know what kind of pushrods should i use, brand, size. thanks
Old 07-18-2009, 03:46 PM
RamAir95TA's Avatar
Are you using SA or non-SA rockers? If you're running non-SA rockers, you need hardened pushrods and guideplates. Stock length pushrods are 7.20" 5/16" rods. If you're reusing stock lifters and the heads have never been off, you can use 7.20" rods. If the deck height, head gasket, or head volume (due to milling) you need to measure for proper length.
Old 07-18-2009, 03:47 PM
AChotrod's Avatar
TFS are good and cheap, measure for exact size
Old 07-18-2009, 04:05 PM
im not sure on the rockers i just bought them and on the webpage it doesnt tell you what they are but ill call them monday.the cc# is 1318-16 if anyone out there knows. im going to take off the heads to do a valve job on them and a mill prob but how do you measure them?
Old 07-18-2009, 04:08 PM
o yah im using stock lifters
Old 07-18-2009, 04:43 PM
AChotrod's Avatar
you need a measuring tool stock lifters are fine if they are in good shape
Old 07-18-2009, 04:45 PM
RamAir95TA's Avatar
I disagree with needing the measuring tool, if nothing else has been changed (or will be changed) on the car.
Old 07-18-2009, 04:46 PM
JB_97ws6TA's Avatar
the 1318-16 is a self aligning roller tip rocker, you can get away without using the hardened pushrods and like it was said earlier in the thread...if the heads have not been off and the deck height has not changed than you can go ahead and use 7.200 inch pushrods but if you so much as changed the head gasket to a thinner one than I would check the length.
Old 07-18-2009, 06:24 PM
im going to go ahead and use new stock lifters, but if i use the same gaskets and do a mill can i use 7.20?
Old 07-18-2009, 06:25 PM
same type of gaskets sorry!!!
Old 07-18-2009, 08:06 PM
JB_97ws6TA's Avatar
If you mill the heads you are going to have to check pushrod length, you need the geometry to be spot on if you are going to get the most from that cam
Old 07-19-2009, 12:10 AM
obviously i dont know that much about all this so dont make fun of me, but do you have to get ones specially made for your car or do they have alot of dif sizes?
Old 07-19-2009, 01:49 AM
BALLSS's Avatar
any time the heads, block have been milled or head gasket thickness changes...length of PR is effected.
7.20" is stock and will "work" with about any change but NOT be spot on if you have made the changes noted. valve guide wear and high RPM issues will be the result of bad valve train geometry or...BOOM is some cases.
get a PR check tool for about $12 and measure. Most PR companies make them in .025 incriments...so if you ned a 7.150" 0r 7.100" (generally the size after mentioned mods) they make that size.
You can "custom" order any length but not necessary to order a 7.023" when a 7.00" will work.
Old 07-25-2009, 12:19 AM
thanks a lot guys
Old 07-25-2009, 04:59 PM
JAKEJR's Avatar
Stock pushrods are 5/16" in diameter and 7.200" in length. So any pushrod that meets those two specs can be used IF no MAJOR changes have been made to the block,heads and, perhaps, head gasket thickness.
Most times, even decking the block or surfacing the heads won't make that much of a difference to call for a different length pushrod BUT it's always a good idea to measure just to be sure.
There are a lot of different pushrods made that fit the 5/16"-7.200" spec, it's just that some types are better than others. Prices vary a lot too.
Most times you'll find that pushrods come in different lengths in .050 increments. For example, stock rods are 7.200 next one's longer are 7.250", etc. The reverse is true when going shorter in length; 7.200" then 7.150, etc.
"Ole Racer's" rule of thumb is it's better to use pushrods that are little too long than ones that are are little too short.
I use TrickFlow pushrods made of 4130 chrome-moly steel with .080" thick walls, they are one piece (NOT having welded-on ends/*****) and are hardened for wear resistance. Those are the specs you should be looking for in a pushrod.
TrickFlows' cost is very reasonable, too, as compared to those offered by CompCams, etc.
Just my thoughts.
Jake
West Point ROCKS!
