cooling shenanigans!
So my car is plagued with issues. I can drive to work and pick my kid up no problem, about a 20 minute trip. I don't believe the car heats up all the way. When I drive more than an hour, or sit in a lot with the ac on my car seems to get so hot that it shuts off. I pray to god I didn't warp the block or crack it for that matter. Here is the dilema my temp gauge doesn't go past like 220. So maybe its the sensor, maybe its the fans? Anyone know a easy way to check what could be going on. I just replaced the thermostat about a 8 months ago (5 months of driving time) with a 160, because it was getting kind of hot. Now, it has shut off the engine twice in the last two weeks. I let the car cool for like 4 hours, and drove it home without the ac on last night, but I will not drive it again until I figure this out. The fluid level is great, and I don't think it could be an air bubble because I would think that the gauge would tell me its still too hot unless the temp sensor is bad. Any input would be great guys.
i have seen my car get past red and never shut itself off, that sounds more like an ignition problem. Car running, A/C on the fans should be running whether it is hot or not. you can check that first. but if it gets up to 220 and is flucuating i don't see it being a gauge problem. now if it was stuck on 220 i could see that being a problem.
ICM's tend to shut your car off if they get to hot. and when cool they will let you run again.
I don't think its an ignition prob, it runs great fast and slow, just not after an hour or so or in heavy traffic for a while. I also live in florida its an average of 90 everyday.
It will stay a lot cooler now, if that was the problem it should be solved.
