Help about to pull motor!!!
You already saw this coming...
Drop it out the bottom.
I dropped my engine and trans together out of my car inside a one car garage with literally a foot of space on either side. I used and engine hoist and a heavy duty strap to lift the body off of the engine/trans/k-member. It's very simple. I can tell you exactly what you need to do if you want to go that route...
Village Troll
The only way you could pull the engine and tranny out together is if you have a load leveler or "happy hooker" as it is also called. Better have your radiator out too. Even w/out the transmission on the engine you will probably still have to tilt it to get it out and avoid contacting the radiator support.
My friend says he actually raises the car on ramps, then pulls everything out from the top. He said when the car is on ramps it provides just enough of an angle to pull the motor and trans out.
I've done it both ways. If you remove the trans from the motor, the motor can come out (but you need to remove the accessory bracket to turn the motor counter clockwise so it lifts right up). Im sure there are other methods
I just kept the Tranny Cross-member in and unbolted the Mount, that worked well.
Pretty much what I did in a way..I raised the front of the body on Jack Stands and unbolted the K-member. Then I lowered the K-member, unbolted the Mounts when the Pully rested on the Sway Bar. The Sway Bar helped lift the Engine off of the Mounts when I lowered the K-member. Then it came up and out with the Cherry Picker.
Took mine out the top & didn't even have to remove the hood.
Dropped it back in from the top w/o issues. Transmission was removed.
I had mine on a ramped lift with the front end lower than the rear by about a foot.
There isn't any room for anything but the engine puller plate bolted in place of the valley cover with a chain hooked through the front hole. I leaft my A/C condensor in place and kept my A/C system charged.
Engine will go in and out no problem if you remove the valve covers.
Good luck.
Good luck.
