fuel line problem
Old 07-23-2009, 09:32 PM
snk-huntr's Avatar
Default fuel line problem
just changed my fuel rail on my 95 ta ,I took the fuel lines off using a small screw driver to get the locks off , now that I put them back on one of the lines leaks if I move the line at all ,could it be the seals or the clips and where can I get them? thanks
Old 07-23-2009, 09:40 PM
RamAir95TA's Avatar
If you used anything but a fuel line removal tool, chances are good you scratched the sealing surface of the lines. I'd take it back off and have a look.
Old 07-24-2009, 12:40 PM
ss.slp.ls1's Avatar
Agreed. Make sure the little tabs of the locks are not bent.
You can get a plastic fuel line disconnect for cheap at Autozone.
Old 07-24-2009, 01:52 PM
shbox's Avatar
You don't ever want to use anything but the correct tool. The connector is easily ruined (as looks like has happened).
Old 07-24-2009, 02:13 PM
the_merv's Avatar
Yea get it off with the proper Tool and check it out.
I hate the ones at Autozone.. I kept losing them, they were too small. O'Rielly's sells one that is a pretty decent size, I keep it in the glove box. I've have it for a few months and that's about the longest time I've hung on to one of them Tools..lol
Quick Reply: fuel line problem
