Comp XFI 280 Dowel pin length problem
Old 07-26-2009, 06:26 PM
Trick450r's Avatar
Default Comp XFI 280 Dowel pin length problem
So I have a Comp XFI280 cam that im about to put into my new shortblock. My problem is that the Dowel pin is much shorter than the one on my old cam, the new one doesnt even stick all the way through the timing gear, let alone into the opti. How do i go about fixing this guys? i need this up and running ASAP!
Old 07-26-2009, 06:33 PM
aboatguy's Avatar
Pin is pressed in
On my 280XFI I had to push it in......so try pulling it out.
MIke
Old 07-26-2009, 07:37 PM
ElkySS's Avatar
^^make sure to pull it all the way out so you can see exactly how long it is. you dont wanna pull it out just far enough only to find out it fell off later and ruined your motor
Old 07-26-2009, 07:55 PM
Trick450r's Avatar
any suggestions on what i should use to pull it out?
Old 07-27-2009, 12:25 AM
JAKEJR's Avatar
Also, if pulled out too far, it'll kill the Opti. The length of the pin differs depending on the year of the LT1.
The pin on the stock cam I just removed from my son's 96 LT1 extends .625". Other years may be different.
Oops, made a typo on pin length, it's .625 NOT .0625 Sorry 'bout that.
Jake
West Point ROCKS!
Last edited by JAKEJR; 07-28-2009 at 01:23 AM. Reason: Corrected Pin Length from .0625 to .625
Old 07-27-2009, 01:50 AM
slownova73's Avatar
yea^^ what he said!
Old 07-27-2009, 10:16 PM
aboatguy's Avatar
I'm lazy I'd grab it with my vice and pull on the cam.
Old 07-29-2009, 08:05 PM
fuel's Avatar
call comp thay will send you a new one .....if you fudge the other one up
Old 07-29-2009, 08:48 PM
fergymoto's Avatar
If the cam isn't already in the motor you can knock it out from the back side with a punch.
Old 08-02-2009, 12:00 PM
Trick450r's Avatar
just in case anyone else runs into this problem, i pulled it out with an old drill chuck. It not even close to long enough to do that job at all so i had a new one made at a local machine shop, problem solved.
Old 08-02-2009, 12:04 PM
aboatguy's Avatar
Was it new, or did a previous owner file it down?
Mine was too long and I had to tap it in..
Old 08-02-2009, 12:27 PM
Trick450r's Avatar
brand spanking new. The pin was about half the length it needed to be...
Old 08-03-2009, 12:46 PM
BALLSS's Avatar
IIRC it would have come with 2 pins, 1 short and the other long
sounds like you have it handled though
Old 08-08-2009, 09:00 AM
aboatguy's Avatar
Mine only cam with the one it was too long and I tapped it in.
I wonder if CC's qc is slipping.
Quick Reply: Comp XFI 280 Dowel pin length problem
