What are the weak points in the lt1 bottom end ?
Just wondering what the weak points are in the bottom end because me and a friend are putting one in a toyota truck how high can we spin this motor safely ? Thanks to anyone with info
because in my 150k mile motor the only problem was a pair of rod bolts that stretched and caused me to eat a bearing up?
that motor had been sprayed, used, and abused. every other part of the motor was in great condition outside of specific parts damaged related due to domino effect.
not trying to say everyone who revs their car to 6400-6600rpm is gonna have the same result I did, the OP asked for the weakest point and it seems to be the most common point of failure in stock RA lt1's that let go. it's not often you see a spun main bearings, snapped crank, bent rods, etc as the source of a failed motor with stock lt1's
Weakest link(s) : Rod bolts, rods, pistons, crank, main caps. If you're going to spend the time and money to rebuild it, why not put some stronger parts? It's worth waiting the extra time to save more pennies
What? No lol. That wasn't in any kind of order. I was making a funny, basically listing the entire rotating assembly being the weakest link =P Plus in my case, yes. Stock 93 rods are much weaker than 94+
Im in the process of building a block for my 94 Z and am using a 95 block with stock rods and crank out of a 95 vette turned and balanced of course. I am upgrading the bolts to ARP's and the pistons because the research ive done tells me they are the weak part. Just dont know what pistons im using yet though
thanks guys i will probably replace the rod bolts and set the rev limiter to 6000 and let her rock. Soon as we get a truck and start the project i will post up pics. Lt1 T56 toyota on the way. Heart beat of Japan lol
