gm 847 cam
Old 07-28-2009, 04:59 PM
blk3rdgen91's Avatar
Default gm 847 cam
ive been searching for a someone who sell's the gm 847 cam...please help
Old 07-28-2009, 05:05 PM
ss.slp.ls1's Avatar
Part# 12370847
http://www.summitracing.com/search/?...12370847&dds=1
I also have one with 1000 miles on my shelf.
Old 07-28-2009, 05:29 PM
96capricemgr's Avatar
A ship date a month out usually indicates a special order. Seeing as that was a CRANE grind I would not hold my breath on getting it from Summit.
Old 07-28-2009, 07:24 PM
LT1
LT1's Avatar
Who all makes the GM847 grind besides CRANE?
Old 07-28-2009, 07:26 PM
Elliott's94Z's Avatar
Just call up AI and have them grind you one comparable
Old 07-28-2009, 07:27 PM
ss.slp.ls1's Avatar
No one, Crane Cams ground the GM847 cam for GM. You could get a custom cam to match the specs:
234/242 .539/.558 112. Don't know the lobe profile though.
Old 07-28-2009, 07:35 PM
robsquikz28's Avatar
just buy his guys ss.slp.ls1
Old 07-28-2009, 07:46 PM
92camaroguy's Avatar
x2 he dont need it lol
Old 07-28-2009, 09:27 PM
97Z28SS's Avatar
ss.slp.ls1 why did you remove the 847 cam?
Old 07-28-2009, 09:52 PM
ss.slp.ls1's Avatar
I never removed it. I bought it used with 1000 miles on it to replace my CC503 when I get heads. I was going to hold on to it. Not sure.
Old 07-29-2009, 03:59 PM
RED94Z28's Avatar
What happened to you i thought you were cc503 for life lol
Old 07-29-2009, 04:03 PM
ss.slp.ls1's Avatar
LOL, I still have the CC503. I bought the cam locally for a good deal to keep on the shelf as an option for when I get ported heads. But I might just keep my current cam. I love it so far.
OP, if you can't find a GM847 cam, Comp is still making the CC306.
Old 07-30-2009, 02:07 AM
monster81's Avatar
GM847 is originally the Crane PowerMax Cam (Part # 109841)
i believe its still available in summit ,,here is the link
http://www.summitracing.com/parts/CRN-109841/
Old 07-30-2009, 06:46 PM
97Z28SS's Avatar
I was wondering because I to have a used 847 cam with less than 100 miles that I'm thinking of swapping in my h/c/i engine that I'm going to swap into my new 94 m6 Z28. The engine currently has a custom comp 230/230 - .560/.560 110 lsa cam or I might hold the 847 for when I build my 383.
Old 07-30-2009, 09:29 PM
myltwon's Avatar
just get a custom cam if you go new
a custom cam from LE isn't much more than a plain jane off the shelf one
Old 07-30-2009, 11:28 PM
shbox's Avatar
The obvious place would be a GM dealer.
Old 07-30-2009, 11:42 PM
myltwon's Avatar
^logic would dictate this
http://www.gmpartsdirect.com/results.html
search for p/n: 12370847
but I'd buy slp's, if you're gonna go off-the-shelf, might as well get a good deal on it
Old 08-01-2009, 07:53 PM
97Z28SS's Avatar
I looked on Ai's website and they have a custom grind that is exactly the same as the 847 except it's on a 110 lsa instead of the 112 lsa of the 847 cam and for NOS the wider lsa will help with that so I'm going to use my 847 when I do my 383.
Old 08-02-2009, 01:41 AM
kenscivic's Avatar
thats a pretty healthy cam for a stock motor stock heads .. just throwing that out there.... whats the lift with 1.6s?
You will have to rev it well past redline to utilize it.
Old 08-02-2009, 06:36 PM
LSWHO's Avatar
That cam will peak at 5800-6000 rpm on stock heads.
Quick Reply: gm 847 cam
