porting high mileage heads
Old 07-30-2009, 04:29 PM
Cruzer23's Avatar
Default porting high mileage heads
if you have over 100k miles on your heads, can you port them and them last another 100k or more miles?
are the chances slim?
is it just not worth the risk?
no problem as long as it passes the hardness test and inspection?
AI has TFS ported heads brand new for $2500
or AI can port my old high milage heads for $2000
Old 07-30-2009, 04:35 PM
RamAir95TA's Avatar
Heads are not a wear component. As long as they pass inspection, I wouldn't hesitate to use a head with 500k miles on it. Don't worry about it.
Old 07-30-2009, 04:44 PM
mdacton's Avatar
might need guides or guide liners, but anything on them can be easily repaired.
Old 07-30-2009, 04:48 PM
djjab57's Avatar
the only way to hurt our heads is if you get them extremely hot, but even then you can usually have them milled
Old 07-30-2009, 04:51 PM
SoxXpupPeT's Avatar
mine had a158k miles on them when i gasket matched them. aslong as there are no cracks or warping your fine
Old 07-30-2009, 05:26 PM
Cruzer23's Avatar
sweet, thanks!
