Anyone using a lunati 60123 or 54799 camshaft (4/7 swap same as 60123)
Old 07-31-2009, 01:03 PM
z28lt1rocket's Avatar
Default Anyone using a lunati 60123 or 54799 camshaft (4/7 swap same as 60123)
im doing a 383 build mild not going for broke status but its gonna cost me some $$$ but heres what i got dart 200cc 64cc cylinder heads weiand single plane sbc intake with injector bosses and distributor block off, cast steel crank (eagle good for 500hp), cast steel rods (scat), kieth black (hypeutethic pistons), 11.8:1 compression, and a intake elbow to run throttle body on the weiand 4150 flange stock computer with a required tune.
this should make 475hp 450ftlb on a good tune modestly
but besides all that i was wondering what this cam would sound like i know its going to be a rough idle but iterested in how rough
Old 07-31-2009, 01:06 PM
RamAir95TA's Avatar
Can't help you on the other info, but yourself a favor and do NOT use an Eagle cast crankshaft.
Old 07-31-2009, 01:10 PM
why wouldnt you use a eagle cast steel crank they claim its WAY strong than cast iron and many others say so also...
im not stubborn or agruing im asking for your opinioon or reasioning...
thanks mang..!
Old 07-31-2009, 01:13 PM
RamAir95TA's Avatar
thanks mang..!
This is a quote from Chad @ Golen Racing:
"We've seen the Eagle cast pieces break time and time again. It's fairly common."
I have witnessed this first hand.
Old 07-31-2009, 01:17 PM
OK i dont want that what other aftermarket brand would you recomend thats still affordable like under 300$ and is good for up to 500 hp
Old 07-31-2009, 01:18 PM
OK i dont want that what other aftermarket brand would you recomend thats still affordable like under 300$ and is good for up to 500hp
Old 07-31-2009, 01:20 PM
RamAir95TA's Avatar
www.ohiocrank.com is what I have in my motor.
Old 07-31-2009, 01:53 PM
thanks
Quick Reply: Anyone using a lunati 60123 or 54799 camshaft (4/7 swap same as 60123)
