Oilpump drive gear anybody have a fix?
Old 07-31-2009, 04:08 PM
T/ALT1's Avatar
Default Oilpump drive gear anybody have a fix?
I am finishing up my new 383 and the last part I was putting on the engine was oilpump drive and then the intake, lastly into the car when I tightened up too much before the plastic cracked. Well it's my fault and I will get a new one unless somebody has an alternative, like a billet part? Just wishing but there was a retainer piece in case the plastic broke anybody have one or now where to get one soon? TIA Clint
Old 07-31-2009, 04:10 PM
96capricemgr's Avatar
Herron performance has a billet one.
https://securehost98.hrwebservices.n...&productId=317
Old 07-31-2009, 04:11 PM
92camaroguy's Avatar
Or if you have a NAPA around they can get you a steel one.
Old 07-31-2009, 04:15 PM
He is not talking about the steel shaft that mates to the oil pump itself. He is talking about the dummy distributor shaft that bolts down in the lifter valley to take the cam rotation and turn it 90degrees for that driveshaft.
Old 07-31-2009, 04:26 PM
Puck's Avatar
Shons is the only one I know of. I need to buy one soon, unfortunatly I had to buy a stock one as well since you need to swap parts onto the billet one. Becoming pretty expensive for such a small simple piece
Old 07-31-2009, 06:59 PM
I should have said I have never had an issue with a stocker. Some guys will bend up little metal tabs to try and retain a stocker in case of failure.
Old 07-31-2009, 07:19 PM
1redta's Avatar
they use to make these
Attached Thumbnails Oilpump drive gear anybody have a fix?-img_0579.jpg   Oilpump drive gear anybody have a fix?-img_0580.jpg   Oilpump drive gear anybody have a fix?-img_0581.jpg
Old 08-03-2009, 09:14 AM
T/ALT1's Avatar
Thanks guys i actually had one built out of billet aluminum over the weekend. I tried to use an olod SBC distributor but the guy helping me said I have some aluminum stock so why don't we just make a new one out of aluminum. After we finished up I looked over on here and saw the link to Shons and ours looks very similar. Thanks Later
Quick Reply: Oilpump drive gear anybody have a fix?
