skipping?
Old 08-06-2009, 07:48 PM
redhot lt-1's Avatar
Default skipping?
well i recently replaced the plugs in my car. well it started skipping well i figured that i broke a wire. replaced the plug wires still skipping. heres the odd part, it idles fine no skip when you put the gas to it no skip but on the road it skips and if you rev it up and as it comes down you can here a raddle in the motor. run a scan on it found a code 0336 (crank position sensor) ordered a new one will have it tomorrow i hope thats it. if anybody has any other ideas let me know. i did pull the valve cover rocker moving good and not lose or broken.
Quick Reply: skipping?
