Help 93 ram air
Help 93 ram air
Ok im sorry if this has been posted once before im a bit of a noob , i have a 93 formula and i am having a really hard time finding a ram air box that will work with out a MAF and that has the wire hook up's that i need. I have been looking at this hood maby it can give a idea to the air box i need.
http://cgi.ebay.com/ebaymotors/Fiber...Q5fAccessories
The MAF is separate from the airbox and since you have a 93' and don't have a MAF it should be easy as all you need is a bit of coupler/tubing to connect it all? Explain better as I am not sure what issue you are having. If it is simply finding a box that is a problem all by itself as they are pretty hard to comeby these days and ebay and craigslist are your best friends to find one.
I have a trufiber hood on mine..its eh ok. but I wouldn't buy it again if i had to do over... look for an OEM one thats your best bet.
93 Ram air
Same as above... My 93 has the hood and air box from a 97. It has a small wire that connects to the factory 97 box.. and as far as the connection to the maf or lack there of.. just used a piece of pvc pipe.
Thanks everyone for the response. I'd like to know whats wrong with the trufiber hood also. Its kinda hard finding oem hoods.
Hey myltwon,
How did you get the LS1 lid to fit? What do you have to do to get it to fit the lt1 throttle body?
Hey myltwon,
I e formula
i heard the air box from a 98-02 firebird will fit under a ws6 style hood i
also saw a 94 trans am with a ws6 hood fitted with a 98 style box with a slp lid on it . the
pics are on this site .WARNING dont buy hood from that ebay site they are **** . buy a trufiber
hood they fit great . about 18 months ago GM discontinued the ws-6 airbox for the 93-97 model
firebird.
94 formula 6 speed hardtop .
firebird.
I've got a harwood I think (bought it off someone) ws6 hood and I made a ls1 ws6 air base and slp lid work (ls1 lid mod, with a twist). Wish I would've known that the trufiber hoods are an oem replica when I was looking for a hood.
and for the coupler, I got mine to go from the maf to the throttle body from intakehoses dot com, you can make the fernco piece fit, but the 4'' end is pretty large, it's made to fit around pvc pipe that is 4'' inside diameter, so it's about a half inch too big, the trottle body opening, if it was circular would be just under 4'' in diameter (same as a ls1 tb)
I have a 93 Formula and I used the Suncoast Creations Predator hood and their Ramair Box, All I did was use a piece of pvc pipe to connect it to my throttle body.
