What do you think should be next on my mod list
-Pace Setter Long Tube Cermaic Coated Race Headers and Off Road Y-Pipe -SLP 2OTL Resonator dumped before axle -EGR and AIR Pump Delete -Walbro 255lph in tank fuel pump -Denny's Nitrous Ready Driveshaft -Moser 12 bolt rear end with larger 33 spline axles, full spool, upgraded performance cover with main cap studs, 4.10 gears, and a 1350 yoke -58mm TB -P&P Intake Mani
Current mod list, ATM. I can not decide were I should go next on my mods. Just looking for a few suggestions. Money will be kinda tight until after the first of the year. Also no Dyno near here, so what would your Estimated guess on WHP be?
I mean if you're doing RR's and springs you might as well slap a cam in there. It's only a couple hundred dollars more (if you're doing the labor yourself.)
not really, you don't have to change springs to switch to RR's. I had to do my intake gasket so I figured I would cam it since I was in there but was tight on $$ so I got a cam kit from AI minus the RR's and springs(which I already had) and it was just over $600 and then spent another $150 at napa on some little things I needed +oil & coolant. I'll do the RR's some other time, popping valve covers is nothing compared to slapping a cam in.
Car is Ram Air so I think ill be sticking with that, I put a Street/Strip Clutch in it last year. Did a proper break in. But the release point seems to still be way up towards the top, I bled the lines but I might need to buy a better clutch any ways. As far as springs go, car came with aftermarket springs. What kind I have no idea...lol...they are stiff as hell and I feel like im rolling along in a damn Stryker...lol..But I'm thinking a mail order tune is a Definite. But I would like to finish up my mods first. I am defiantly going to Juice her next year, I want a Vortech SC but the kits are just way to expensive.
PS Sorry it took so long for me to reply, I worked a double shift. I am getting married to my daughters mother as soon as she gets back from Iraq. So we are saving up for a house.
