ls1 driveshaft question???
Old 08-13-2009, 04:30 PM
ls1adamls1's Avatar
Default ls1 driveshaft question???
ok so i went to put my ls1 driveshaft in my 97 lt1. when i went to bolt it in the ujoints would not go into the yoke.
i have the stock ls1 ujoint on my ls1 shaft, i put the end caps off the lt1 onto my ls1 shaft and it did not work.
so what ujoint do i need to get so i can bolt it in there?????
part number would be great too.
Old 08-13-2009, 05:09 PM
ss.slp.ls1's Avatar
Never heard of anyone havaving that issue. It's a direct replacement. Mine bolted right up as it should. Do you have pics to illustrate your issue?
Old 08-13-2009, 05:13 PM
ls1adamls1's Avatar
no i dont. so all i need is the standard ls1 ujoints?
Old 08-13-2009, 05:15 PM
ss.slp.ls1's Avatar
The u-joint on the LS1 ds and LT1 ds is identical AFAIK. Even if they aren't, they fit the same and can be used in a LS1 or LT1 car alike, as it should because the rear ends are the same.
Old 08-13-2009, 05:22 PM
ls1adamls1's Avatar
ok cause the end caps off the lt1 ujoint dont fit onto the ls1 ujoint properly. so ill buy a new ls1 ujoint and see if it fits.
Old 08-13-2009, 05:26 PM
shbox's Avatar
If it is all stock to stock parts, it should be a direct swap and no fitment issues.
Old 08-13-2009, 07:58 PM
ls1adamls1's Avatar
ok but the lt1 ujoint caps do not fit on my ls1 ujoint is what im saying. '
so if i get ls1 ujoint caps it will fit is what everyone is sayin
Old 08-13-2009, 08:04 PM
Badazz 97 TA's Avatar
stock LS1 caps are the same as LT1 caps. maybe the guy put bigger u-joints on the DS and yokes when it was on his car
Old 08-13-2009, 08:14 PM
ls1adamls1's Avatar
well all i know is the caps went on the ls1 shaft but stuck out too far to sit in the grooves on the yoke.
Old 08-13-2009, 08:31 PM
robsquikz28's Avatar
it will fit with no change of parts, just swap driveshafts and thats it.
Old 08-13-2009, 09:27 PM
the_merv's Avatar
Actually, there are 2 different ones..I know this cause I had them both side by side.
The Steel LT1 shaft I had was a 1310 Series U-joint on the D/S side, 1330 on the Yoke side for the Rear, the front Yoke was a 1310 D/S, 1330 Yoke to the Tranny. It looks like a little conversion U-joint.
The LS1 Shaft I currently have was 1330's all around, I replaced the back one for a 1330/1350 Yoke for my Moser. The 1LE Spicer Shaft I have is the same way.
Hopefully this explains it for you.
Old 08-13-2009, 10:00 PM
shbox's Avatar
There was only one pinion yoke used on all rear ends from 93-02, so that's a little perplexing. You'd think whatever ds he has, it would fit the in the pinion yoke.
Quick Reply: ls1 driveshaft question???
