Deleting Emisson Stuff
Im replacing the Intake Gasket so why not the EGR is messed up so im gonna delete it all and make cleaner engine bay. I got Intake Manifold off and the EGR stuff off already. What needs to be Caped off?
You should have gone with the UMI block off plates, as when you get them the one that goes on the header is way to thin. It wont seal for ****. You will either have to get another one or weld up the hole on the headers
all 3 times, Its not my dd i only drive it on nice weekends. So yes i let it sit for at least 24 hours, one time 48. the problem was there is only one bolt holding it on and its so thin. And if you try to tighten it up to much to bottom end will just start bending up
yah actually that pipe can be removed completely instead of capping it..
are these pics from your engine or some you found? you said "headers"..pics are stock manifolds..
taking that stuff off isnt gonna help..i have another thread going right now where we're discussing that pipe lol...everyone says they just cut it..it looks like if you removed the oil cooling lines..you MIGHT be able to finagle it out..but i think i'm just gonna cut mine tomorrow
