dipstick tube
Old 08-17-2009, 09:52 PM
rat93's Avatar
Default dipstick tube
I sanded the paint off of the majority of the tube (leaving enough at the end bump for a seal) and oiled it. Now, it slides in with ease until it hits the small amount of remaining paint. I cant get it to budge for the life of me. Should i sand the rest of it off and use an o-ring to create a seal?? Thanks
Old 08-17-2009, 10:19 PM
SoxXpupPeT's Avatar
your talking at where the tube goes into the block. correct ? i used high heat silicone and slipped it in and covered it up. worked out good so far for me
Old 08-17-2009, 11:59 PM
iceman15's Avatar
I heard alot of guys had goodluck with putting it in the freezer and freezing it.
Old 08-18-2009, 03:32 AM
monster81's Avatar
as Soxx said, apply high heat slicone only on the end of the tube where it seats in the block and remember that the tube bracket will be bolted to the block so it will never slip out, the silicone is only to ensure a proper seal nothing more
Old 08-18-2009, 01:15 PM
2XR95Z28's Avatar
I had trouble with puttin mine in also, is the "bump" on the tube supposed to go into the block or just supposed to be butted up the the lip in the block?
Old 08-18-2009, 02:09 PM
fleetmgr's Avatar
It just butts up against it.
Old 08-18-2009, 02:31 PM
2XR95Z28's Avatar
that would explain the troubles i had lol, time to order a new dipstick tube hahah.
Old 08-18-2009, 05:32 PM
airfix's Avatar
I hate taking out the dipstick tube. After taking it in and out a few times I got the feel to get it in easy everytime. (well atleast on my car) try being gentle and lightly wiggle it in lol. I know thats tough to do bcz after the first few mins of trying you wanna bent the F#$%ing thing over your knee and throw it in the garbage. But ya lube er up and gently slide it in, just like your well you know lol.
Old 08-18-2009, 06:18 PM
bigchevyman24's Avatar
lmao...that just made my day...especially after the problems I had putting mine in. I sanded up to the "bump" down to bare metal, applied some oil and wiggled it back in. I didn't apply any silicone. No leaks so far...
Old 08-18-2009, 08:29 PM
2XR95Z28's Avatar
From the sounds of everyone elses replies it sounds like the "bump" is supposed to go past the lip and into the block? Am i wrong here? any more confirmation on whether its supposed the bump is supposed to go in the block or just butt up against the lip?
Old 08-18-2009, 09:05 PM
Badazz 97 TA's Avatar
from what i remember it just butts up againts it. I dont think it physically goes into the block. once its flush bolt it up to the block with that 10mm bolt
Old 08-18-2009, 09:16 PM
Z28_LT1's Avatar
as long as that little bolt goes in ur good.
Old 08-18-2009, 09:27 PM
RamAir95TA's Avatar
Push tube into block. Align bracket with bolt hole on block. Bolt tube in place.
Done.
Old 08-19-2009, 01:44 PM
rat93's Avatar
Done.
WOW, is that really how you do it?
Thanks to (almost) everyone for the advice, im going to go get high heat silicone now
Old 08-19-2009, 02:03 PM
FlamingChicken's Avatar
i think i used an old injector o-ring on my tube. couldnt get it to seal for whatever reason using rtv.
Old 08-19-2009, 03:50 PM
RamAir95TA's Avatar
Don't know if you're being sarcastic or not. Stupid internet.
Old 08-20-2009, 09:28 AM
Al 96 Ram Air T/A's Avatar
Make sure you get the RTV designed for oil. Some are better than others against oil degradation and heat. The block does not get awfully hot, so no need for extremes.
Old 08-20-2009, 10:59 AM
AChotrod's Avatar
Helpfull hint. If your having trouble gettin the damn bolt back in, slot the hole in the dip stick so you can start the bolt then just slide the dip stick behind it and tighten it down.
Old 09-08-2009, 10:05 PM
Sarge91's Avatar
I did a header install, and i lost the dipstick tube bolt, that goes into the block. Does anyone know what size bolt i need? I have one in holding it in till i can find one. The one that i got to go in is way to long. Thanks
Old 09-08-2009, 10:11 PM
AChotrod's Avatar
Done.
This what I just did!!!! Although I did have probs with mid length headers on my 97. Then I just slotted the bolt hole on the dip stick and bam!
Quick Reply: dipstick tube
