Need answer quick!!
Old 08-18-2009, 07:31 PM
red-_-z28's Avatar
Exclamation Need answer quick!!
Witt the rear end cover off what is the visual differance between limited slip and standard. Trying to figure out what oil to put in thanks.
Old 08-18-2009, 07:40 PM
red-_-z28's Avatar
It's a 1996 z28
Old 08-18-2009, 07:44 PM
AChotrod's Avatar
all z28s were limited slip unless the posi broke.
Old 08-18-2009, 08:14 PM
Village Troll
SS RRR's Avatar
80w-90 will work fine. Also need to get limited slip additive which can be purchased at any auto parts store.
Old 08-18-2009, 08:15 PM
red-_-z28's Avatar
this is my rear end which type is it?
standard or limited slip?
thankyou
Old 08-18-2009, 08:19 PM
am_muscl's Avatar
that differential looks like the Auburn gear I had. That is a limited slip differential, and it should have posi-traction
Old 08-18-2009, 08:20 PM
am_muscl's Avatar
you can tell, did you ever do burnouts in the car? If yes, did both back wheels spin or just one? if it's two, that's posi traction, if one then its standard
Old 08-18-2009, 08:32 PM
red-_-z28's Avatar
Okay thank you so muchh and both tires spin so yahh
Old 08-18-2009, 08:36 PM
97badass's Avatar
put it up on a jack put the car in neutral and spin one of the tires, if they go the same way then its posi.
Old 08-18-2009, 08:38 PM
Badazz 97 TA's Avatar
basically, limited slip still allows the wheels to turn at different speeds. For instance, taking a right or left turn. The inside wheel is gonna spin slower then the outside wheel. The limited slip allows for that difference but both tires will still spin when you do hit the gas..
a locker will not allow the wheels to turn at different speeds. both axles are "locked" together.
Old 08-18-2009, 09:19 PM
Z28_LT1's Avatar
ah, learning something new everyday..
Quick Reply: Need answer quick!!
