having issues after tune up please help!!!!
so my car was tuned up sat and that day it ran fine until it heated up and then it would surge at idle but now it has a skip and will not blow the tires off in 1 st gear or any gears.
the car seemed like it was running on 7 cylinders so i checked the plugs and wires
i found a plug wire loose and i put it back on tight to the spark plug and now it does not skip as bad but it still is not right
the car does not feel like it has the power it had before the tune up
any ideas why the car is not running right
this is aggravating me that i paid for a tune up and it runs worse now than it did before
the car is a 95 z28 lt1 stock with mods in sig
any thought's would be helpful
thanks
thanks
ok now i got some different issues
we found a burnt plug wire so got the skip straightened out
but it still surges only at idle, and its hesitating and the exhaust is popping every once and a while at WOT,
im leaning towards o2's or could it be the fuel pressure regulator????
