need help with injectors
i am in stalling ford 42 injectors and i cant get the retaner clips to stay what do i need to do. or do i even need them there going on a lt4 elderbrock intake and heads.
If I remember correctly there are 2 slots at the top of the SVO injectors but one does not go all the way around the injector and I believe that is the top one. You have to utilize the lower slot and it moves the injector up in the fuel rail so it seems like there is not enough room for it to seat in the intake manifold but it does, you just have to make sure that your fuel rails are properly mounted. Hope this helps
