Is it my head gasket? Pictures inside.
I took some pics of the oil tube after I got to school and turned off the car.
I took of the oil cap and looked. Smoke came out of that tube, and also from the coolant reservoir. I am not smoking white smoke, I am losing coolant and the car has overheated.
EDIT: I forgot to mention that while filling up the radiator, and letting the car warm up the coolant kept bubbling and pouring over the fill neck even after the 4 minute warm-up.
And lastly, while coming home this morning from a short drive to get some breakfast and idling in my parking spot white smoke did start coming out the exhaust tips. It's 74* out right now, and the car had gotten up to operating temperature.
I smelled the exhaust but I didn't smell the sweet smell of coolant, smelled like normal exhaust to me, unless that's not how it's supposed to smell?
haven't really noticed any loss in power, it's actually felt good, but I was too scared to give it any gas today. The last couple of times after running perfectly cool, and I decided to gun it, it quickly overheated (or the temps got up there lightning fast).
The oil I'm using is 0w30 and I just changed it. I did check the oil dipstick and I didn't notice any milky substance, but the oil on the stick was pretty thin/runny to me.
check your oil dipstick it might look watered down and smell/look like coolant....also check your radiator cap it might have that under the cap or have a brown look in the radiator. Indicating oil in the radiator, or if you have a block check it will tell you immediately.
yeAH, I have recently overheated. My thermostat got stuck about 3 wks ago and my temp gauge wasn't working. That same day I was doing some runs on a backroad. I think that's what caused my problems. Plus it's overheated sometimes after that, the result of a radiator hose coming off (my mistake).
I guess I'll have to do that.
Or maybe I'll check the oil I just changed.
If it's the head gaskets, I feel like going LE1, but I may not be able to scrap the cash together.
Borrow a coolant system pressure tester from AutoZone and see if the system can hiold pressure.
Looks like a head gasket failure to me.
Jake
West Point ROCKS! Nation's TOP COLLEGE per FORBES Magazine!
Jake
