Spun bearing
Spun bearing
Couple of questions about a spun bearing:
1. Can you still drive the car (no hard) without causing more damage?
2. Can you replace the rod bearing inserts without dropping the engine?
3. What can be damaged from a spun bearing?
4. How do you know which bearing is spun?
5. And can the bearing be spun without the crank being damaged?
Thanks!
Thanks!
take the car off the road as soon as possible to avoid siezing the motor or destroying your heads once that rod lets go. i will post pics of what it looks like if you decide to drive on it when i find my camera.
the knock was heard at 2500rpm and was very quiet for about 2 months so i knew it was on its way out. then it all of a sudden got really loud driving home from work (6 mile trip) so i parked it and eventually pulled the motor to find this:
http://i73.photobucket.com/albums/i2...mulaoilpan.jpg
and this:
http://i73.photobucket.com/albums/i2...rankdamage.jpg
and this:
http://i73.photobucket.com/albums/i2...ingremains.jpg
and this:
and this:
