LT1 valve train on TBI motor?
Old 09-21-2009, 05:13 PM
01yellow4.8's Avatar
Default LT1 valve train on TBI motor?
I'm pretty sure that this will work well, but I just want to confirm. Will the valve train from an LT1 work with a TBI from a truck with vortec heads? How will this perform as far as power increase?
Old 09-21-2009, 06:31 PM
myltwon's Avatar
what parts specifically are you planning on swapping?
springs, pushrods, cam, lifters, rockers?
Old 09-21-2009, 11:30 PM
Basically everything. I just didn't know if the springs from the lt1 would fit on the vortec heads. Also I didn't know if the pushrods were the same length as the tbi pushrods. Is this swap even worth the time?
Old 09-21-2009, 11:37 PM
the_merv's Avatar
I don't see why it wouldn't fit.. just about everything SBC is the same..
Old 09-22-2009, 08:11 AM
myltwon's Avatar
probably require different shims as I know the iron and aluminum lt1 heads require different ones and a vortec head is basically a foreward cooling bbody head
might be a little gain, like the equivilent of when people used to put "rv" cams in cars but nothing worth much hassle unless you got alot of free time and free parts
Old 09-22-2009, 11:53 AM
Village Troll
SS RRR's Avatar
'87 and up roller valve trains are the same.
Quick Reply: LT1 valve train on TBI motor?
