ARP bolts, help out with part nums and such
Old 09-24-2009, 01:59 PM
TheDon619's Avatar
Default ARP bolts, help out with part nums and such
Hey guys im in the process or putting my motor back together and need to order some bolts i got a few just making sure i got what i need and seeing what else i need to get it finished.
ARP 134-3701 - ARP High Performance Series Cylinder Head Bolt Kits
View Image and Compare
* ARP 134-3701 - ARP High Performance Series Cylinder Head Bolt Kits
Cylinder Head Bolts, High Performance, 12-Point Head, Chevy, Small Block, Kit
Part Number: ARP-134-3701
Transaction
* $61.75
* $61.75
* Remove
ARP 134-5502 - ARP Engine Blocks
* ARP 134-5502 - ARP Engine Blocks
MAIN STUDS
Part Number: ARP-134-5502
Transaction
* $69.95
* $69.95
* Remove
WarningsOut of Stock
Warnings
close
This part is temporarily out of stock, but you can order it now. Tentative ship date: 10/12/2009
ARP 134-6005 - ARP High Performance Series Connecting Rod Bolt Kits
* ARP 134-6005 - ARP High Performance Series Connecting Rod Bolt Kits
Connecting Rod Bolts, High Performance Series, 8740 Chromemoly Steel, Chevy, 350, LT1/LT4, Set of 16
Part Number: ARP-134-6005
Transaction
* $63.88
* $63.88
* Remove
ARP 534-9703 - ARP Engine Bolt Kits
* ARP 534-9703 - ARP Engine Bolt Kits
Engine Bolt Kit, Chromemoly, Black Oxide, Chevy 1992-97, 5.7L, LT1, LT4, with Headers, Kit
Part Number: ARP-534-9703
Transaction
* $163.95
* $163.95
Any help would be great guys. thanks
Old 09-24-2009, 03:40 PM
chavez885's Avatar
Wrong stud kit I believe.
Old 09-24-2009, 03:45 PM
RamAir95TA's Avatar
Splooge for the polished stainless steel bolts. They're worth it!
Old 09-24-2009, 03:56 PM
Stroked96Bowtie's Avatar
SBC and LT1 kits should be one in the same right?
These are good:
http://www.summitracing.com/parts/ARP-134-3601/
Better:
http://www.summitracing.com/parts/ARP-134-4001/
Best:
http://www.summitracing.com/parts/ARP-234-4301/
The 12 point are easier to get on and off if you can shed the extra coin. Then again how often will you be taking them off
Old 09-24-2009, 05:00 PM
TheDon619's Avatar
the stud kits right thats stright from ARPs site its a new kit for the lt1 using stock windage tray
Old 09-24-2009, 05:06 PM
93Z2871805's Avatar
I used 234-5602. That's splayed caps w/Hex Nuts w/o windage tray. Use that if you're going to use a pan with a built in one. Use 5501 for lt1 w/windage tray and then use the bolts provided from the company that makes the splayed caps. I couldn't figure out if you had splayed or not in the PN numbers list above.
Quick Reply: ARP bolts, help out with part nums and such
