Confused on LT1 oil capacity
I am using the standard size K&N oil filter along with M1. Is the capacity 4.5 quarts or 5 quarts? I was told 5 quarts.
I put 5 quarts in last night and the level on the dipstick is about 1/8" above the crosshatch area. Therfore according to the dipstick, its barely overfilled.
What is the correct oil capacity on LT1 and when is it overfilled?
Here is what the owner's manuals actually say and it is not going to help the confusion any:
1993
Camaro/Firebird 4.5
1994
Camaro/Firebird 5.0
1995
Camaro 4.5, Firebird 5.0
1996
1997
Camaro/Firebird 5.0
This is with filter change if the manual mentions it.
Just fill it to the full mark on your particular dipstick.
Mine has always been perfect with 5 qts at filter change (using the old short filter).
1993
Camaro/Firebird 4.5
1994
Camaro/Firebird 5.0
1995
1996
1997
Camaro/Firebird 5.0
1993
Camaro/Firebird 4.5
1994
Camaro/Firebird 5.0
1995
1996
1997
Camaro/Firebird 5.0
1993
Camaro/Firebird 4.5
1994
Camaro/Firebird 5.0
1995
1996
1997
Camaro/Firebird 5.0
Would you lose any sleep if the level was 1/8" above the full indicator on the dipstick?
I've done oil changes with all kinds of filters (Wix, ACDelco, Fram, K&N, you name it...) on both my car (95 formula) and a list of others as well..94 TA, 96 Z28, 95 Z28, 96 Impala SS...them and every LT1 car I worked on at the Lube express took exactly 5 quarts too...
I'm guna go with 5 quarts...
did you run the engine at all after the 5qts were put in? did you fill the filter before you installed it?
run the engine for a minute, turn it off, let it sit for a minute or two then check the level.
