Do I have a time bomb (Opti) - LS1TECH
Thread Tools Search this Thread
Old 10-07-2009, 02:01 PM   #1
J2Pharren1's Avatar
Default Do I have a time bomb (Opti)
So I bought a 96 Z28 recently. Runs really strong, very clean, good deal, all that. It has 143k on it right now but the engine was replaced at 136. I called the dealership to get a run down of what exactly was replaced, and when they installed the new motor they re-used to orginal opti but replaced the plugs, wires, and did a cap and rotor kit on it. So I have a distributor with 143k and a cap and rotor with 7k on it, the new(ish) water pump has like 12k or so.
Car seems to run perfectly fine, but that does seem like quite a lot of miles. Should I plan on it going relatively soon?
J2Pharren1 is offline   Reply With Quote
Old 10-07-2009, 02:09 PM   #2
wrd1972's Avatar
Dont worry about till it shows syptoms of failing.
wrd1972 is offline   Reply With Quote
Old 10-07-2009, 06:58 PM   #3
J2Pharren1's Avatar
What might some of those be? Like a stumble in the mid range rpms right?
Old 10-07-2009, 07:06 PM   #4
Quote:
yep, or various other ignition related problems. theres a million threads on here about opti problems. but i mean if it aint broke dont fix it.
nik1703 is offline   Reply With Quote
Old 10-07-2009, 07:15 PM   #5
chavez885's Avatar
160k on original opti here, if it's not broke, don't mess with it. Cap + rotor changes should make it last a while.
chavez885 is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
