CC503 Cam
Old 10-17-2009, 07:17 PM
DVS BSTD's Avatar
Default CC503 Cam
I'm new to the F-Body world and am looking for the actual part number to this cam and was wondering what else is required when installing this cam...
also what kind of gains are to be expected with this cam
thanks
Old 10-17-2009, 07:25 PM
robsquikz28's Avatar
here ya go- CC503 Cam pn 75038
CC NSA 1.6 RR's 7/16" pn 1305-16
-GMPP Guide plates
-ARP Rocker Studs 7/16" pn 1347103
-CC Behive Springs pn 26918-16
-Spring locator pn 4705-16
-CC Steel retainers and locks pn 787-16 & 648-16
-LT4 or LT1 Timing Chain
-CC Hardened Pushrods pn 7808-16 or I have some for sale
-CC High Energy Lifters pn 850-16 or LS7 lifters
Old 10-17-2009, 07:36 PM
LT1
LT1's Avatar
While back i compiled a list of stuff to go with a None Self Align setup if thats the way you want to go here is what i came up with. Part numbers are from Summitracing.
CCA-07-503-8 CC503 (224/230 .503/.510 112 LSA)
CCA-1305-16 Pro-Magnum Rockers 7/16" stud (1:6 ratio)
ARP 134-7103 Arp (Rocker Arm Stud) 7/16"
TFS-30400623-8 Trick Flow guideplates
CCA-26918-16 Beehive Spring or PAC 1218 springs
CCA-795-16 Steel Retainers (LT1 for 918 springs)
CCA-4705-16 Seats
CCA-611-16 10 degree Lock (11/32 super lock)
12499225 LS7 Lifter Kit
Trickflow 5/16 Hardened Chromemoly Pushrods (youll have to check what length you need.)
Old 10-17-2009, 07:39 PM
DVS BSTD's Avatar
whats the best choppy cam for a damn near stock motor
Its a 95 Z28 A4 - K&N CAI, Straight Piped Exhaust, thats all I got so far
I want a good choppy cam that has good gains
Old 10-17-2009, 07:56 PM
LoudGM's Avatar
I had the cai, lt's, 1.6 rr, and cc503 and put down 330rwhp on a mail order tune with my old lt1. It was pretty choppy too.
Old 10-17-2009, 08:16 PM
DVS BSTD's Avatar
so you dont need that stuff its just recommended to get it?
Old 10-17-2009, 09:09 PM
Noah's95z28's Avatar
Oh NO! you definatly need the stuff both guys listed. Im not sure about the timing chain though. I dont think you NEED to upgrade it, but if your engine has higher miles it would be something to go ahead and upgrade since you are already there.
Old 10-17-2009, 11:00 PM
kamon8404's Avatar
Damn seems pretty pricey and a lot of work.
Old 10-17-2009, 11:30 PM
93v8clone's Avatar
goin cheap is like bangin a 2 cent ***** ,sure it gets the job done but a lot of problems arise .go spend a little more money and get a good ***** "or parts " and do it once and not have to worry bout it
Old 10-18-2009, 12:11 AM
onefastmx5's Avatar
Is there a resonably priced LT1 timing set part number? The ones I've come across are like $350.
Old 10-18-2009, 12:52 AM
TRANSAM GT4's Avatar
I bought a Cloyes for under 100.
Old 10-18-2009, 12:59 AM
Revson's Avatar
You have to run guide plates with a 503? Why won't sa rockers work?
Old 10-18-2009, 01:49 AM
LT1
LT1's Avatar
Yes you can, and if you go the cheap route with no guide plates then you wont need the longer 7/16" ARP studs, instead you will need to get the Self Align rockers 3/8" stud.
Do not run Self Align rockers 3/8" stud or any Self Align rocker for that matter with guide plates, if you do you will have metal shavings all over (a big mess!)
Old 10-18-2009, 09:38 AM
myltwon's Avatar
I just replaced the chain itself when I did my cam swap only like 20 something bucks
as for a ghetto parts list, here's where I come in
-USED CC503 $130 shipped
-NEW Crane 10308-1 Spring Kit $180
-NEW Comp Magnum SA Rockers $170
-NEW replacement timing chain $20
-NEW Comp Hi-Energy 7.200" Pushrods $30 (optional)
then of course you got gaskets, tune, fluids, etc.
Old 10-18-2009, 02:41 PM
StealthFormula's Avatar
-GMPP Guide plates
LT4 timing chains only work with LT4 sprockets. Also want to get the Trick Flow guideplates because many times the GMPP's have a couple that are not hardened in the set.
I use to run the cc503, here is the parts that I recommend:
-Crane 10308-1 Springs
-Comp NSA Pro-Mag 1.6RR's 7/16" or any other RR that is NSA and 7/16".
-Trickflow Guideplates
-ARP Rocker Studs
-Trickflow Hardened Pushrods 7.200" (Assuming your heads were never milled etc.)
-Go to your local Chevy dealer and order stock valve stem seals
-New stock LT1 timing chain
-GM LS7 Lifters
I never did a before and after dyno but I picked up about 6mph or so from the cam, rockers, tune. The car trapped 110mph through my automatic at a 3700# raceweight at the time.
Old 10-18-2009, 02:57 PM
jays97 t/a's Avatar
well he said he has an A4 so you would want to get a stall to go along with it and if your tranny has high mileage you will need to rebuild it..then you will need a good tune so it runs right..you would think putting a cam in would be pretty cheap but its really not if you do it right
Old 06-06-2010, 12:03 AM
stangkiller2005's Avatar
I know this thread is old but I have a question. What will happen if I run the cc503 without the roller rockers? I understand it's better to but money is tight and fixin it up slowly
Old 06-06-2010, 12:09 AM
YOu can run the cam with out the roller rockers. Your just leaving power on the table.
Old 06-06-2010, 12:17 AM
Wicked94Z's Avatar
buddy of mine put down 359/354 with stock rockers on a stock heads and cc306, I was surprised as hell to see that number. madz28 mail order tune no less, A/F was dead on though. Am i saying run the stock rockers? No, but I doubt it will kill more than about 10 hp.
Old 06-06-2010, 12:37 AM
Cool thanks guys
Quick Reply: CC503 Cam
