Track results! Think I can pull a 12 next time?
Old 11-07-2009, 11:06 AM
cgEvan's Avatar
Default Track results! Think I can pull a 12 next time?
Last night, I did this on a base map tune. It was so off the car would barely crank due to flooding. Standing behind the car, you can literally smell how bad the tune is off.
Previously, I did this, with worse tires and exhaust, but on a stock tune...
Think with a badass tune, I can get my 12.99?
Old 11-07-2009, 11:18 AM
LSWHO's Avatar
That mph is kinda low for 12s. It's possible tho. Just wait for perfect conditions.
Old 11-07-2009, 11:21 AM
cgEvan's Avatar
I'm hoping the tune will help me up top, as it's leaving the line pretty good. I agree though.
Old 11-07-2009, 01:37 PM
SPEED#1's Avatar
If you get those 60s down a bit more you can with no problem...
Old 11-07-2009, 01:41 PM
LSWHO's Avatar
uhh. Easier said than done. I mean sure, if he wants to hit 12s once he could blow the rearend up. But, not being able to back up a run kinda defeats the purpose.
Old 11-07-2009, 02:08 PM
gregrob's Avatar
Why so rich? A "base tune" shouldnt be that far off for your mods.
Old 11-07-2009, 02:27 PM
cgEvan's Avatar
Knowing my car, a sensor probably went out before the races... LOL.
Old 11-07-2009, 03:09 PM
gregrob's Avatar
Lol I hear you there
Old 11-07-2009, 03:18 PM
Badazz 97 TA's Avatar
your times looks almost exactly like mine. i still havnt hit 12's though. i pulled a 13.000@105. 1.8 60ft. your car is almost there. you might need a few more ponies to hit a 12.99 IMO or just a higher stall converter
Old 11-08-2009, 07:48 PM
OddballLt1's Avatar
A better tune will put you the 12's easy. I went 12's with the stock converter/LT's and 3.73's. Its not very hard honestly.
Old 11-18-2009, 09:42 PM
cgEvan's Avatar
Turns out I had a bad knock sensor, so less timing than stock. Now with new knock sensor, plus more timing from a better tune. Hoping for 12s Saturday.
Quick Reply: Track results! Think I can pull a 12 next time?
