ABS inop after led 3rd brake light
Old 11-07-2009, 11:46 PM
squeals99's Avatar
Default ABS inop after led 3rd brake light
so yeah i put a led third brake light in today and sure enough the abs inop light came on... any fixes to this?
Old 11-07-2009, 11:48 PM
94LTZ's Avatar
You need to put a Relay in line
Old 11-07-2009, 11:54 PM
squeals99's Avatar
how much resistance do i actually need? and where can i put one that wont be a pain?
Old 11-07-2009, 11:57 PM
94LTZ's Avatar
I'm working on that actually for my car after the LED install with my SS spoiler, but the easiest location is where the brake light and the wiring harness actually meet under the plastic cover in your trunk lid, not sure on the resistance you need but if you find out let me know lol
Old 11-08-2009, 12:07 AM
squeals99's Avatar
lol will do... my dad's an electrician so ill have to have him check it out... possibly put the old bulbs in again and see what they put out and then try to match that...
ill def let ya know if we figure out anything
Old 11-08-2009, 07:53 AM
1993 z28 f1's Avatar
Hey:
Check your cruise control out if it does not work you'll have to add a resistor pack to get it to work again with LED tailights.
Dub
When In Doubt Do Without
Old 11-08-2009, 08:13 AM
shbox's Avatar
http://shbox.com/1/relay_for_ss_spoiler.jpg
Old 11-08-2009, 08:21 PM
squeals99's Avatar
thank you sir!
Old 11-08-2009, 08:37 PM
airfix's Avatar
I Followed the how to on shbox website. Worked awesome.
Old 11-09-2009, 04:18 PM
squeals99's Avatar
question though... where can i find this relay?
Old 11-09-2009, 04:21 PM
LT1
LT1's Avatar
Autozone or any auto store
ask them for the automotive relay with the 87, 87A, ,30, 86, 85 pin.
ive used this type of relay for a lot of things on my cars like eletric fan's, push button start, ect...
Old 11-09-2009, 05:35 PM
airfix's Avatar
I just pulled out my a/c relay and got them to match it up at the auto parts store.
Old 12-13-2009, 11:04 PM
TopFlite's Avatar
Subscribing. I'll be installing an SS Spoiler with the LED as well.
Old 12-13-2009, 11:24 PM
95_transam_lt1's Avatar
why would a led 3rd light cause an abs inop light?
Old 12-13-2009, 11:34 PM
shbox's Avatar
Because the LED (as opposed to the bulbs) does not provide the resistance the ABS and cruise uses to tell if the circuit is intact.
Old 12-14-2009, 09:25 PM
makes sense
Old 12-14-2009, 09:32 PM
wrd1972's Avatar
Yeah the PCM expects to see the x ohms value of resistance provided by the two light bulbs. Just match the value with a resistor and use a relay.
Old 12-14-2009, 11:18 PM
shbox's Avatar
The actual mod to use the relay uses the relay coil as the resistance (relay not used in the normal fashion). The relay coil is used because common resistors cannot handle the amps of the circuit and dissipate enough heat to be safe.
Old 12-15-2009, 06:49 AM
wrd1972's Avatar
Ah I see. I assumed it had to see a certain OHM value.
I have the LED spoiler and LS1 tail lights myself. The LS1 taillights have two additional bulbs in them so my PCM still sees the actual bulbs like it wants. No relays needed if you do this mod.
Quick Reply: ABS inop after led 3rd brake light
