hp gain? Comp Cams K07-467-8 Camshaft Kit Lt1 280Xfi Hr-13
how much HP will that Kit gain for stock 95 Transam?
1995 firebird Trans am ALL STOCK.. auto transmission 4l60e.. only Catalytic canceled if its important
Cam-only cars require all of the accommodating valve train parts (rockers, etc.) in your cam kit. It goes needless to say that the cars with a cam that big need longtubes, ory, gears, stall (if auto), and a tune to run at their best potential
Your a little ahead of yourself there man. It's good that you asked before diving into things though! You want to start with your basic bolt-ons before thinking about a cam. You want to open up the air flow so start with a cold air and move into the exhaust system with a set of headers and a catback. With an auto car, unless you plan on running a small cam, it is required to run a larger stall converter. With a converter comes a shift kit and tranny cooler. As you can see there is alot to be done before a camshaft should even be considered if you want a car that performs properly.
So at the end of the day, if you want your car to run correctly and to its full potential... It is going to cost you a pretty penny. I'd also recommend shorter gears to compliment that cam setup.
How many miles are on the car?
Start off with some longtube headers, off road y-pipe, plugs, wires, catback, 3.73 gears (I love them), Yank ss3600 or vig 3600 stall, tranny cooler, shift kit, and if you have money left after that, get the cam kit. (also get a nice dyno tune or if on a budget do PCM4Less or comparable tuners) Either way if you get all the accommodating parts I said but not the cam kit, send your PCM off to Spend Inc (like I did) or PCM4Less and have them calibrate your PCM for the gears, stall, and modifications.
