LE1 cam And LE2 heads dynoed By Fresno Performance
#41
Dyno numbers are easily manipulated and do NOT translate into track performance.
The dyno numbers are nice but MEANINGLESS, track numbers are a better indication of performance.
#42
Well Caprice I do agree with you about the track times if you are speaking of what mph the car runs which is an indication of how much power the car is making but et is more an indication of how well the chassis, trans/converter, gears and tires are sorted out then how much power the car is making.
#43
Village Troll
From what I read he has a valid point.
#44
I apologize but douche bag does not seem to be a valid candidate for spell check in my spell check software. But if it makes you happy, I have now added it for future usage.
And what was that point?
If you want to compare dyno numbers to see who's faster, its meaningless. Clearly, this is not what I did in my post that he was referencing. Most sane people do agree with this.
I was comparing dyno numbers with very similar engines to make a determination that something may be a bit off on my setup. My numbers were a good bit off from the OP again with similar setups. I said I found a problem that might have been present (based on lots of evidence and weird things going on) the last time I was on the dyno and that my tune might be bad.
IMHO, he took my post completely out of context, accused me of derailing the thread to start a flame war.
So again. What was his point?
#45
You guys need to get a life and drop the subject! It's really not that big of a deal. Don't get butt hurt over what someone says on the internet.
BTW, though, those are awesome #'s.
#46
"Will pass" and DID pass are two very different things. It would be prudent to get it tested before saying it definetely will. We have ALL been sure of things that never panned out.
My car is mailorder tuned, seems to work OK. The f-body community puts way too much emphasis on dyno time.
#47
Sounds like you had a pcmforless tune. I used him at one point and since wised up. Good tuners can get reliably close to perfect by mailorder and some datalogs can refine it further.
Your cam is most definetely not "emissions legal" it might pass emissions but that does NOT make it legal. To make it truely legal the manufacturer has to pay huge fees to CARB. Of course noone is going to tear the motor apart to find it.
#48
this video is a perfect example:
http://www.youtube.com/watch?v=9iNCMVE2emE
Driver car(LT1 Z28) went 10.36
M1 went 10.1 in 1000ft
#50
Now i to am a believer in track times proving all,i own 3 single digit cars two being total street cars.But in some cases a hands on tune is a must.We also fixed a rocker arm on the dyno and advised a good adjustment point for him aswell.Again stuff you dont get with a mail order tune.
#51
#52
You are absolutely correct in “will pass” and “did pass” I should defiantly get it tested. But the cam is a small smog legal cam is the point I was trying to make that’s all. As far as the mail order tune, I will never run one again after seeing how far off the was. The car had way to much timing in it and it was extremely lean so lean that the base line dyno had to be aborted at 5100 rpm because it the was 18.9 to 1 lean and getting leaner. In my opinion mail order tunes are hit and miss usually miss, an example of this is that Nathan found 40 more RWHP out of it and made the A/F super safe (12.8 to 1 across the rpm rang).
Now get it to the track and hush some people up about dyno tuning being a waste of time,and how the numbers are fake.
#54
my dynojet wide band.
when i street tune i use my trusty old aem wideband,ive ran it side by side with my dyno wide band and its within .1 of my dynos wideband.I can also recheck my dyno one and i do often.
#56
I can tell you right now,if starbucks would have raced his car,he would be putting a new motor in his car real soon on the mail order tune,a/f was 14.5 at WOTand timing was at 38 degrees and had a ton of knock.The mail order is a very nice starting point,but if the guy is 2000 miles away its pretty tuff to get it nailed..
You are looking at this from the perspective of someone who gets PAID for dyno time. I am looking at it from the perspective of someone who has to get the most of his dollar.
The price of a dyno tune would buy me PARTS. Granted it takes a little more time to dial them in off the dyno but it absolutely can be done.
OR would you be willing to say I will gain substantially with a dyno tune?
#57
im saying a perfect dyno tune is cheapier then a new motor.im sry a mail order is just that.mail order.i wont do them.to many things can go wrong to quikly.but stick to ur mail order tunes from a tuner 1000s of miles away.good luck.
#58
and ur comment about beimg paid to do a service.well im very picky on my tunes.i loose money if i were to charge by the hour because i refuse too let a tune go thats close.it has to be perfect.then i spend another half hour to hour on the street to make sure its 100% perfect.again ssomething someone 1000s ofmiles away cant do.
#59
Thanks again Nathan excellent customer service even after the tune. Trust me as soon as famaso is open I will be there at the gates ready to race this car. As far as the dual exhaust I plan on doing that as well but going to have to save some money up first, but defiantly something that is going to happen.
