how do you install arp rod bolts
You can easily swap rod bolts without a press the thing is after the bolts are installed you NEED to bring the rods to a machine shop to have the big end resized....some shops will resize rods with the piston still on there and some will not....personally i would order a set of scat I-beam rods for 250.00-300.00 but thats just me.
and to resize the rods they would press out the new bolts so they can take just a little off the parting surface so they can rehone them to size.
So either bring the rods to a shop and let them do it, or bring them the whole rotating assembly and rebalance with the Scat i-beams
