help me for convert LT1 to carb
How are you all
I need your help to me convert LT1 to carb
Of readings in the forum know that I need to convert the engine lt1 to carb is
Antiques and Carpritr and distributor spark to engine 350
but you will be problems within the engine
such as Voices in the Plouffe
Thank you all
The chap is a fellow Arab, seems like his English skills are a bit limited.
Bro, write in Arabic and I will be happy to translate.
Either way, you need the LT1 carb intake, a carburetor, fuel pressure regulator, a distributor that will fit in the tight space, hoses for the fuel delivery.
The second a question
Do I need change something inside the engine such as pistons
And a thousand thanks to you and apologized for not to speak the English language well
I will speak Arabic now
Thank you
عزيزي
ارغب بتحويل محرك من طراز
lt1
الى كاربريتر بدل من البخاخ
والان تم تحويلة ولاكن خفت من صرقعه البلوف والمحرك الى الان لم يشتغل فهل تحويلها الى كاربريتر سوف بسبب صرقعه ؟
او يحتاج تغير الى بساتم تخفض الكمبريشن ؟
المحرك لن اضيف علية اي تعديل راح يشتغل ستوك لاستعمال اليومي
لك كثير الشكر
What car is this engine going to be in?
Guys, correct me if I'm wrong, but he won't be able to run his 4L60E with his PCM unless he has a 93 which would mean already a 700R-4.
I do not care for the air cleaner
I am interested in only one which is important
To worry about a shortage of gasoline for the engine makes her his internal problems of the vote and spoke to him break out in the valves or piston
(( want to switch away from fuel injection? ))
yes because of Computer problems and wires because the vehicle off-road (( Carp simple maintenance ))
Thank you
Like the guys said, no need to change anything inside the engine. Whatever they tell you to buy is what you need.
Thank you
The engine will be installed in a vehicle of the type Patrol 4 * 4
but
Writing that the Red Balloon
Did you mean Gearbox?
The image car
