Let's roast this guy...
I mean ahem "educate" him....
I'll post a few of the dumbass comments he has made.
Watch out guys, this man is a ******* mechanical genius. He said so himself....
I was gonna try and make a useful post, provide him some links to the fact that the radiators are exactly the same as an SBC, minus a few external differences (recent thread on here) and links explaining just what reverse cooling is, and some info about the fact that aluminum would be better in a salt water environment vs cast anyway... but I figure why bother, he is on such a higher plane than the rest of us mere mortals that anything I could say would pale in comparison to his vast knowledge....
Here's a link to the youtube vid comments... http://www.youtube.com/comment_servl...%3DxZjCR_MR2mg
Lets burn this clown to the GROUND!
Originally Posted by TheDieselDr
and BTW your wrong about any intake fitting no matter the generation.....
on the 1987-1999 SBC
(1pc RMS and centerbolt valve covers)
the two middle sets of intake bolts,
the holes are drilled at a diffrent angle from the other 8!!!
yea pn# 2104 Edelbrock no ****
this is not my first rodeo,,
I appoligize if I sounded a little harsh
it's just that I am a mechanical genius
and sometimes I come off sounding like a dick, I am a self employed diesel mechanic and I'm the type of dude that can show up on your farm with a few wood blocks and a 5T bottle jack and split a tractor in half and do a clutch job in 2hrs
I have a 91 X-cab Chevy I put a
LT-1 and 6spd in that runs like a raped ape,,,
I want to put a LT-1 in my 19.5ft Glastron
but I want iron vortec heads, not aluminum..
Originally Posted by gregrob20
Well, you're kind of retarded there Mr. mechanical genius because you're not going to get reverse flow iron vortec heads, becaue they dont exist. The LT1 is reverse flow, your stuck w the aluminum heads. Dont know why you would want to put much worse flowing iron heads on it anyway, but more power to ya...
that dude gregrob20 is a idiot, I want iron heads because I plan on running my boat in saltwater!!! besides that vortec heads will fit, who said I can't use a Lt-1 short block with say vortec 305 heads ( the chambers are smaller),, with a TPI intake?
and a open set of hooker headers turned upside down,, **** normal, I want it loud!!
amazing the amount of dipshits you run into around here.....
yea..... do you really think it's the head's fault they get cooled first (reverse flow)
or the WATERPUMP'S!!!!
I'm kinda leaning towards the pump being the reason for the reverse flow,,
I'm not "stuck" with any head,, you did know the caprices and impallas had iron heads huh??
mark Cambell up at Street & Performance sell the parts to get rid of the opti spark for a HEI and the Gear drive water pump,,
damn illeagletalon beat me to it but he's right and so am I,, the water pump is the reason for the "reverse flow" not the heads... I know ways to do away with the opti spark and the shaft driven water pump,, and another thing I'm as far from retarded as it gets homeboy
WRONG. Do some more research, homeboy.
If you honestly think GM changed the water passages in the block and heads to make the "reverse flow"
(the heads get cooled first) you are a bigger idiot than I thought,, This is a fact>> when I did the
LT-1 swap in my truck the stock radiator was *** backward,,,
>>> meaning the Lt-1's water pump suction is aiming at the drivers side of the engine witch just so happens to be opposite of the ol TBI305's suction side,,, witch is on the pass side at the bottom,, get over it you are WRONG
Originally Posted by "TheDieselDr
Believe me if I didn't have to buy a $600 dollar custom Griffin radiator to have the suction side on the drivers side at the bottom, I wouldn't have,
reasearch LMAO >>>> your funny
"LT-1"= standard SBC w/mickey thompson (M/T) valve covers (i believe thats how they came?)
"LT1"= reverse cooled genII SBC, nothing similar between the two refering to the block, intake and heads,
LT1 block has different water pump ports and different coolant passages
LT1 heads have different coolant passaes
LT1 intake, NO coolant passages, and different bolt locations and angle's!
LT1 is a factory roller block
LT1 radiator and SBC radiator= NO DIFFERENCE (reffering to inlet/outlet). i know because the direct fit aluminum 3 row radiator in my NOVA originally made with a SBC, worked just FINE with my LT1
but i could be wrong once the "Mechanical Doucheness" "dieselDr." gets in here
I hope you school him well, he needs it, I think his surgery should be closed the self proclaimed diesel genius doctor that he is.
Dub
When In Doubt Do Without
Here's the link: http://www.youtube.com/comment_servl...%3DxZjCR_MR2mg
You guys log in and help me here!
ill see if i can find a link to the article for u guys.
anyone that is a self proclaimed mechanical genius is a F*cking hard plastic helmet wearing Idiot.
that is the reason why he is self employed no-one else wants his a$s around..
sounds like crazyz28 or whatever his name is that frequents the forums
info about the original "LT-1", and i think i read the m/t valve cover **** somewhere else so i apologize for that comment.
"The LT-1 350 represented the last hurrah for the high-squeeze, solid-lifter small-blocks, as the '71 version made due with just 9.0:1 compression compared to 11.0:1 for the 1970 model."
http://www.superchevy.com/technical/...ing/index.html
Here's my latest:
My God you're dumb for a self-proclaimed mechanical genius.
1) It's LT1 no LT-1... get it right the LT-1 is a completely different engine.
2) LT1 block has different cooling passages than normal SBC
3) LT1 head has different cooling passages to match the block
4) Rotation of the water pump has NOTHING to do with reverse cool, the engine doesnt know which way the damn water pump turns
5) 305 vortec heads will NOT fit an LT1
6) TPI intake will NOT fit an LT1
7) Aluminum does better in corrosive environments than cast iron so your argument for that is retarded.
8) An F body LT1 radiator is EXACTLY THE SAME INTERNALLY as a standard SBC radiator... There are a few external differences such as mounting tabs for the fans etc..
9) The LT1 intake has NO provisions for coolant flow and the bolt holes are completely different, it will NOT bolt up to a normal SBC, vortec, etc.
10) All this just proves to me you are FOS and have nevere even had an LT1 apart, let a lone put one in your truck or boat.... If you had, you wouldn't say stupid **** like this, unless you are genuinely retarded. In which case I hope the next tractor you split open with your mechanical wizardy squashes your ******* head like a watermelon. Would do the world good to rid it of the ignorance you emanate.
