p0100 problem
Old 01-24-2010, 04:30 PM
shutzero's Avatar
Default p0100 problem
Car is throwing p0100 code...replaced the maf and I'm still getting the code...any other ideas?
Old 01-24-2010, 04:36 PM
69gto96z's Avatar
My car did this, I replaced the MAF and it was still there. The car was sputtering and not driving very good either. The harness that runs down by the pass side header had gotten too close to the header and melted. I pulled the harness out, extended every wire, and ran the harness down the back side of the motor to keep it away from the header. Fixed the MAF problem, and I no longer have to worry about that harness burning on the header again.
Is your car still running alright, or is it sputtering?
Old 01-24-2010, 04:42 PM
shutzero's Avatar
It still sputters at idle sometimes, but I only drove it for like 5 minutes
Old 01-24-2010, 04:43 PM
69gto96z's Avatar
I'd check that harness. How long have you had the headers on there?
Old 01-24-2010, 04:52 PM
shutzero's Avatar
About 15 months
Old 01-24-2010, 04:56 PM
69gto96z's Avatar
Hmmm, would be kinda weird for that harness to burn after that long. Is the pigtail going to the MAF still in good shape?
Old 01-24-2010, 04:58 PM
shutzero's Avatar
Probably could be in better shape, where can I get one?
Old 01-24-2010, 05:03 PM
69gto96z's Avatar
I got one a couple years back from the dealership. Couldn't find one anywhere else.
Old 01-24-2010, 05:08 PM
shutzero's Avatar
part number pt1604?
Old 01-25-2010, 11:36 AM
69gto96z's Avatar
not sure on the part number
Old 01-25-2010, 08:18 PM
shutzero's Avatar
maf and pigtail both replaced...light still comes on...and after i clear the code it comes right back on within a second of it being cleared...any other ideas? i check some of the wiring real quick and it doesnt look like any of the wires got melted
Old 01-25-2010, 10:48 PM
69gto96z's Avatar
Is it still running crappy? Do you have the MAF facing the correct way? It sounds stupid, but it would cause issues if it is not facing the correct way. Other than that, I am out of ideas. My buddies 97 was not running good at all, was backfiring horribly, and throwing a P0100. Turned out he had some crossed wires after installing his last opti, we fixed that and the code went away. I think that was just a coincidence though.
Old 01-25-2010, 10:51 PM
69gto96z's Avatar
Also, check your fuses, I know when my car was having MAF problems there was a 20 amp fuse in the fuse box that had blown.
Old 01-25-2010, 10:52 PM
shutzero's Avatar
car actually runs fine, stumbles rarely at idle, where would the fuse be located?
Old 01-25-2010, 11:03 PM
shutzero's Avatar
it turns out the 20amp eng sensor fuse was blown, would this have caused it? why would it blow?
Old 01-25-2010, 11:48 PM
shutzero's Avatar
I replaced the fuse and it blew again...what could be causing this?
Old 01-26-2010, 12:48 AM
69gto96z's Avatar
That is the same one that blew on my car. I believe there is a number of things that can cause it to blow, but im not sure what they are, other than the wires in that harness shorting out by the passenger side header.
Old 01-26-2010, 06:36 AM
shutzero's Avatar
I guess I'm going to have to follow those wires and see what happens
Old 01-28-2010, 03:50 PM
shutzero's Avatar
passenger side header? can u get me a picture or something so i can see where they run to
Old 01-28-2010, 06:19 PM
shutzero's Avatar
The fuse blows right when I put the key on, I couldn't see any problems from the wires coming from the pigtail up to the first set of injectors on the driver side
Quick Reply: p0100 problem
