Ls1 lid conversion with fitment issue: Wich rubber coupling do i use ?
Old 03-10-2010, 08:42 AM
always faster's Avatar
Default Ls1 lid conversion with fitment issue: Wich rubber coupling do i use ?
Well im doing my Lid conversion(slp lid,complete lower air box and FTRA).I got a harwood ws6 ram air hood so i dont need to cut anything and i dont want to,so no cutting on the rad or the hood or the frame, etc,etc....Im having a trouble to make the connection between the MAF and the TB.Like a lot of people told me here ,i ve bought a Fernco 3inch to 3 inch coupler but it doesnt fit perfectly.So i would need help to finish this once and for all
I dont have my camera to take pics but i ve found the exact problem that i have on the board so here it is:
https://ls1tech.com/forums/attachmen...s-pics-002.jpg
So you can clearly see that the maf is angle down while the tb is level
What would be your solution(dont wanna cut the lid please)?
I was thinking abour a 45degree 3inch coupling but not sure about that,i want the most smooth way possible.Link is only there for example:
http://cgi.ebay.co.uk/BLACK-76mm-3-S...item439915f34d
Thanks
Old 03-10-2010, 10:10 AM
1redta's Avatar
I have the same hood and problem. I used a straight Fernco 3" to 3" and a peice of the moroso CAI to help span the distance. I think I am going to pull the MAF out of the lid and use a small peice of silicon to space the maf out and then use the fernco from the maf to the tb
Old 03-10-2010, 10:56 AM
96lt1m6's Avatar
The stock Ls1 boot works just fine
Old 03-10-2010, 11:00 AM
Didnt think about that
I will keep this solution has a backup if i cant make it with one boot only.
Your talking about the accordion one...i was thinking about a smooth one so the flow would be optimal.
Old 03-10-2010, 11:07 AM
tdevil55's Avatar
Try this site:
http://www.siliconeintakes.com/produ...1d3e8043dfc0e2
Old 03-10-2010, 11:13 AM
96lt1m6's Avatar
There is absolutely no true gain in the different boots but its your choice. No gain or loss at the track on my car.
Old 03-10-2010, 01:22 PM
the_merv's Avatar
I have a smooth one..4" in diameter..goes from my TB to the MAF, I needed the 4" cause I have a 90mm TB and the Z06 MAF.
I don't see why a 3.5" wouldn't fit the oval LT1 TB..maybe it needs to be a 4" to 3.5"..4" on the TB side, and 3.5" on the stock MAF side. I had to use one like that for the MAF to the Lid..
Not sure about which particular one fits a stock LT1 TB..I'm sure someone knows though.
Old 03-10-2010, 01:53 PM
RamAir95TA's Avatar
I'm pretty sure I used a 3" Fernco on my build. It looks like it won't fit at first, but if you boil it, it will stretch out pretty good.
Old 03-10-2010, 02:00 PM
ks my ss's Avatar
I am using one of these. Although I don't have a MAF anymore.
http://intakehoses.com/Merchant2/mer...ory_Code=CACH5
Old 03-10-2010, 02:20 PM
the_merv's Avatar
Originally Posted by RamAir95TA
..it will stretch out pretty good.
That's what she said..
Old 03-10-2010, 02:37 PM
96lt1m6's Avatar
lol fun fun
Old 03-10-2010, 04:31 PM
gregrob's Avatar
I used NO coupler from the lid to the MAF. If you try it the MAF slips inside the lid and fits perfectly. At least it did on mine. It's so tight I dont even need a clamp.
On the MAF to TB end I used a Fernco and didn't boil it. Just manned up and put it on the TB.
The following users liked this post:
Ted Kay (01-19-2020)
Old 03-10-2010, 06:47 PM
96lt1m6's Avatar
exactly what i did!
old pic from the beginning of LID swap
Old 03-10-2010, 07:48 PM
fastfox's Avatar
I did the same thing worked great.
Old 03-10-2010, 07:54 PM
Marc3.4V6's Avatar
I know it's more money, but I thought I heard the SLP smooth bellows works perfectly, is that true?
Old 03-10-2010, 08:06 PM
1redta's Avatar
I can get the 3" fernco on the TB no problem. If you call that "manning up" you probaly have a worn out mangina.
The reason my MAF isn't in the lid ANYMORE is to help with distance from the lid to the TB. See, I didn't cut one part of my car up to do this( Thank You Harwood hood ) I trimmed the bottom of the ls radiator support to accomplish this and it all fell into place
Old 03-11-2010, 11:31 AM
Vicious95Z28's Avatar
i think most of you guys that didn't have issues with it is because you didn't use the lower ls1 support. It raises the lid alot and changes the angle going to the tb, that's where the trouble starts. I've had the same issues as this cat so I know where he's comin from. I should have the proble solved in the next day or two tho.
Old 03-11-2010, 11:43 AM
the_merv's Avatar
^^Yea that angle is a bitch..I have the LS K-member with my Engine, I don't know if the LS Intake/TB sits higher than the LT1..I think it may just by a little bit.
Old 03-11-2010, 09:43 PM
You got it
When you dont use the lower airbox the lid output sit at the same level has the tb.But when you use the complete assembly it make the ouptut ouf the lid higher and give it a damn angle...
Old 03-12-2010, 11:36 AM
Originally Posted by always faster
You got it
Hey G,
I got mine working last nite, I just got another short coupler and slipped over the lid exit and the MAF. All is well, the car screamed up high last nite!!!
Quick Reply: Ls1 lid conversion with fitment issue: Wich rubber coupling do i use ?
