Some Questions about 96 camaro steering column
Okay I have this 96, the steering column got destroyed because of an ex, she lost the key and to unlock the steering column, she used a screw driver. I wasn't there for all this, so don't flame.
My question is, Can I go to a junk yard, buy a steering column with the matching key for that column. Install it and not have to worry about the anti theft device?
I know our keys have that little metal chip, that sends an ohms reading to the computer, telling it is the right key. And I know how to by-pass this. But I would need the original key to get the ohms reading from it to know the right resisters to buy for it. But since I don't have it, and have to purchase a whole steering column and key. Will it work?
Or
Do I just need to take the VIN number to the chevy dealership, get the correct key, check ohms, buy the resisters, by-pass that. And throw away the key?
Thanks.
Or
Thanks.
There are like 20 possible resistor values. You can just buy the 20 resistor values and keep trying until one works. Or you can take your VIN to the dealership and see if they would be able to just give you the chip value or ask them to just measure the resistance of the chip needed. Otherwise you'll have to bite the bullet and buy the key.
Nice. Thanks for the info.
Any chance you know were I can get the 20 resistor values at?
I am sure if I go to the dealership, they won't have that chip for that car. They will have to just run the VIN, and order it.. Sucks!!!
Just my $0.02...
The thruth is there are actually 15 different resistance values for the key. If you get a new column, you will need the key that goes with it, because only the profile of the key that matches the lock cylinder of that column will let it turn. Then, you will need to know the resistance value of the old key pellet (which you may not have). You will need a key that matches the physical profile of the new column with the pellet value from the old key.
The column does not determine the key pellet resistance-it only sends the value to the VATS module. If you call a dealer with your VIN, they just might tell you the pellet number you need so you can get a key made. They normally want proof of ownership. They would make you a new key, but you would need to discuss your situation so they don't make one that fits the old columm.
Hopefully you will be driving over Deception Pass again in no time.
Thanks for the info guys.. I will just buy the column with key, and head over to the Dealership..
shbox, thanks. I haven't driven over the pass in a year, Been in afghan.. You prior military?
If you're going to pay the $ for a new key, you might as well put it to good use.
Take them the VIN of the car and tell them to make you a key with that pellet value but have them cut the key for the new column.
