LT1 Header Question
LT1 Header Question
I have a 95 Formula with BBK Ceramic shorties, I want to go with Long tubes, but some of the long tubes im finding dont have the air injection bungs on them, is that something I can by pass or do I need to use those??
so what does it take to get rid of the AIR and EGR, just simply removing it or do I have to by pass it?? This is my 1st LT1 car, so I dont know alot about them, im more of a mustang or LS guy, so the help would be great, because id like to order headers tonight!
Do you know where I could get those emissions blockoffs at?? And when you say codes deleted just simply hook my snap-on scanner up to it and clear them?
Well I ordered new headers and cat less y-pipe with out the air and egr BS, and then ordered these from Herron Performance, so I hope this is all I need, if not let me know!!
https://securehost98.hrwebservices.n...od&productId=3
......by block offs on ebay $15 ,buy headers on ebay, available w/air and wo/air ,Yes the stainless with y-pipe for $375 are good products. before you get them search this forum for everything you need to know about insall'n em ....on ebay type " lt1" and there is like 4,000 listings for about anything you want.... common name for the install thread can be found by typing "LLP"
What headers/y-pipe did u order? Check out my sig for some of the better pricing on products (and a sponsor)
well theres no inspections here, and I bought the block off plates from Herron Performance and the LTs with Y-pipe for like $340 shipped off ebay, thought for the price id try them out, they are stainless steel so they should hold up the rest of the summer, ill be doing a 383 stroker this coming fall/winter, get ready for the 2011 race season, and hoping for high 11s with all motor as well, and I hope my spec clutch will keep holding up, best money ive ever spent!! I also have all new spark plugs/8.5mm wires/msd cap, thought id do it now as well!!
Heres what I ordered!!
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_2971wt_892
Cool same ones i got, i cut all slip joints installed headers and welded turbo v-band flanges in to elem. leaks and fix final fitment .....ebay
Im hoping to gain some with the long tubes, cat less y-pipe, over the factory y-pipe and bbk shorty headers, car already runs hard, should be a lil better now!! Thanks guys for the help!
So I recently bought a 94 lt1 trans am already fitted with pace setter "race" long tubes and a cat-less Y-pipe... Unfortunately I live in a county where the sniffer emissions test is required. So after some cutting, welding, and fancy custom fab I have a functional egr system and cats. Now in my attempt at the emissions place I was sent home with a failure notice for "high hydrocarbons" which I understand is unburned fuel passing through the exhaust.. Am I going to have to figure out a way to attach my air injection system to these pain in the rear headers? In my understanding the air injection's soul purpouse is to burn raw fuel in the exhaust, correct?
Thanks
Thanks
