best cam for cam only set up
Old 06-27-2010, 09:21 PM
cgperformance1320's Avatar
Default best cam for cam only set up
motor is 100% stock im sprying 150 but want alil more till i build the new motor. what would be the best cam to go with ?
Old 06-27-2010, 09:27 PM
slomarao's Avatar
Id pick up one AI/LE's custom grinds. The 226/234 should do the trick. Or the cc503(224/230)
Old 06-27-2010, 09:42 PM
im gunna need valve springs, rockers, a converter, and a tune anything im missing other then gaskets and **** like that
Old 06-27-2010, 09:44 PM
slomarao's Avatar
timing chain, at least a new stock one. Valvetrain parts(pushrods, lifters, etc) LT4 HD would be nice but I am guessing you on a budget.
Old 06-27-2010, 09:53 PM
i dont want to spend a million but i dont want it to break a week after i put it to gether
Old 06-27-2010, 11:56 PM
big_bird_93's Avatar
AI has a cam kit on their site for like 1100... What else would be needed that kit doesnt have if anything?
Old 06-28-2010, 01:17 PM
gunter96ws6's Avatar
ive always liked the 306. youll see alot of people say its outdated technology which is kinda true but it makes good power with stock heads and it responds well to the giggle gas.
Old 06-28-2010, 02:24 PM
T/ALT1's Avatar
I have ran both the 224/236LE and a CC306 both worked great behind a stalled auto. The 224 is more of street N/A cam where the Cc306 is more street/strip for higher rpm and loves n2o. My car ran 11.61@117mph with the 224 on motor with LE1's. Then with bigger valves, more portwork and CC306 it ran 11.20@120.8mph N/A with 3.42's in the 10bolt! It also ran 10.17@134mph on 175HP n2o. I have also helped a friend with a CC 305 220/230 really nice driver camand makes good midrange power, full weight car ran 12.10@110mph. The bigger the cam, the more converter you can use so you have to decide whats acceptable and go from there.
Old 06-28-2010, 02:28 PM
sweet-94z28's Avatar
cc503 is the most optimal cam for stock heads.
The lift/duration combination uses up every bit of the stock head's potential. The cam still is very driveable and has an awesome power band.
Old 06-28-2010, 03:06 PM
96lt1m6's Avatar
LPE 211/219
makes awesome TQ very smooth, almost undetectable sound and runs very good especially with spray makes for a stealthlike powerhouse!
Old 06-28-2010, 05:26 PM
NewOrleansLT1's Avatar
LPE 211/219, LT4 Hot Cam, cc305, cc503 just to name a few...
Old 06-28-2010, 06:28 PM
robsquikz28's Avatar
a.i 226 cam will be perfect
Old 06-28-2010, 06:34 PM
wow theres alot of different opinion
Old 06-28-2010, 07:35 PM
96lt1m6's Avatar
Thats the good part of our forum you have many people that have used other product and can give an account of how their combo worked out. I really suggest reading TOP BUILDERS LPE,TPIS etc. All their stuff is easily streetable,maintain emissions on most applications(if thats an issue)and are quite driveable aswell as dependable. Nitrous is an awesome addition to an Lt1 well anything that has a combustable engine.....
Every cam mentioned so far is a good choice you have to select the one that best suits your needs along with your supporting mods...
Old 06-28-2010, 07:43 PM
i dont care a bout street abilty i just wanna go fast! lol
and im in florida so no worries about emissions
Old 06-29-2010, 01:09 AM
gregrob's Avatar
Dude this has been BEAT TO DEATH.
You are never going to get one straight answer from anyone.
If I had to buy an off the shelf cam it would be the Lunati 219 cam.
The baby cam we designed for my car will soon be going 12.90s at extreme DA (7500+) with a 6 speed full weight car. I regularly walk on cars with ported heads and lots more done.
Another cam we did similar to mine put down 401 RWHP with a set of LE2 heads.
I feel I can design something better than the shelf stuff for a cam only setup, but there are a lot of good cams out there you can run and make good power as well.
The one mistake people make is going too big. The stock heads dont complement too big of a cam.
If you want to go fast, keep the cam small duration wise, and concentrate on making the rest of the car work.
Old 06-29-2010, 09:36 AM
Wicked94Z's Avatar
Old 06-29-2010, 03:37 PM
LadyDriven's Avatar
If you decide to go with a cc503, I have one for sale, PM me
Old 06-30-2010, 05:25 PM
Big bird55's Avatar
pm sent
Quick Reply: best cam for cam only set up
