LT1 oil filter M1-111, M1-202, M1-302 ??? - LS1TECH
Thread Tools Search this Thread
Old 07-17-2010, 10:43 PM   #1
96silverram's Avatar
Default LT1 oil filter M1-111, M1-202, M1-302 ???
Just wondering if anyone knows about the Mobil M1-111 (will it fit the 96 LT1), M1-202 (may have been discontinued) this is what I currently have on the car now, but I'm wondering if the M1-302 is the same physical dimensions and can it be used as an exact replacement for the M1-202?
Thanks
96silverram is offline   Reply With Quote
Old 07-17-2010, 10:54 PM   #2
camar0corey's Avatar
Is the one number a truck filter or something? I know I'm about to start running whatever truck filters are compatible, because they just cut the size of all LT1 filters in half about six months ago(every manufacture to my knowledge, that I have seen), I have no idea why but I'm not happy about it!
camar0corey is offline   Reply With Quote
Old 07-17-2010, 11:20 PM   #3
I use the m1-302 which is a long filter.
lt1-xjs is offline   Reply With Quote
Old 07-17-2010, 11:24 PM   #4
is the M1-302 the same filter as M1-202 (discontinued). Same physical dimensions ?
M1-302 is the truck filter
Old 07-17-2010, 11:32 PM   #5
old93camaro's Avatar
i use the m1-113 i think its the small one
old93camaro is offline   Reply With Quote
Old 07-18-2010, 04:37 AM   #6
i use the tall one, i look in the manual and look under 1996 for whatever the v8 van is and it is the same filter as listed for our car but taller. i think it was 302
zbomb5610 is offline   Reply With Quote
Old 07-18-2010, 09:35 AM   #7
Z28Roxy's Avatar
Quote:
You can also look for the filter for an 87 silverado will give you the right part #s.
For mobil 1, it's M1-302. For K&N it's a similar number, also has a 302 somewhere in there.
Z28Roxy is offline   Reply With Quote
Old 07-18-2010, 09:57 AM   #8
killagt's Avatar
302 or 303 will work fine.Why not use napa gold 1060, its cheaper and work great, its also long filter .
killagt is offline   Reply With Quote
Old 07-18-2010, 09:58 AM   #9
lt1slowz28's Avatar
M1 111 is the one im using. regular old size. 302 is bigger
lt1slowz28 is offline   Reply With Quote
Old 07-18-2010, 07:46 PM   #10
I can only use a certain length of filter because my FLP longtubes get in the way of most filters. I went to O'reilly's today and found the WIX filter will work and the K&N 2002. I decided to get a K&N because it has a socket fitting on the bottom for removing the filter easily (tight tolerances to get your hand in where the longtubes are). I measured the K&N, it is 4.25" vs. Mobil 1 M1-202 (@ 4.10). So, this should work as a great replacement for the Mobil 1
Old 07-18-2010, 08:10 PM   #11
killagt's Avatar
K &N and Mobil 1 is SAME filter. just 1 dollar different, I heard royal purple is good filter cause it use synthetic material it can go 15k + miles, too bad only pepboy have it, no pepboy around here.
Old 07-18-2010, 08:27 PM   #12
Z28Roxy's Avatar
Quote:
Sometimes you get good combo deals on oil + a m1 or k&n filter. But only one or the other.
Old 07-18-2010, 08:48 PM   #13
killagt's Avatar
advance auto have mobil 1 5quart + mobil 1 filter for 30 buck, good deal if you ask me.
Old 07-18-2010, 08:51 PM   #14
Z28Roxy's Avatar
I have seen german castrol syntec (6 quarts) + m1 or k&n filter for $28
Old 07-18-2010, 09:08 PM   #15
Quote:
i pay that price for conventional oil pretty much, i use over 7 quarts per oil change, damn milodon oil pan and larger oil filter.
Old 07-18-2010, 09:09 PM   #16
killagt's Avatar
where ? that a dam good deal if you ask me, only autozone have GC, I already check autozone it have 5 quart GC with fram tough gaurd ( only good filter fram made )
Old 07-18-2010, 09:29 PM   #17
Z28Roxy's Avatar
It was at autozone like a year ago.
Old 07-18-2010, 09:42 PM   #18
i think the k&n version is HP-2002. Its a big filter also.
Badazz 97 TA is offline   Reply With Quote
Old 07-18-2010, 09:47 PM   #19
killagt's Avatar
why are you mention old stuff lol, let talk about something on sale now, not year ago hahaha.
Old 07-18-2010, 09:48 PM   #20
killagt's Avatar
Quote:
yes its.
Related Topics
Thread Thread Starter Forum Replies Last Post
76gts aka "pt76/75" ***pics added*** L92 fox Parts Classifieds 13 12-17-2012 06:39 PM
SMJ ABS Delete/linelock (pics) derekbuckner1 Drag Racing Tech 11 09-09-2012 09:15 PM
First Gen Camaro Tic Toc Tach 68Problemchild Conversions & Hybrids 0 09-26-2010 08:27 PM
Over size filter for 93-97 lt1 ? killagt LT1-LT4 Modifications 1 06-05-2010 10:45 AM
Im I using the wrong oil filter ? Mobil 1 killagt LT1-LT4 Modifications 6 05-02-2009 05:15 PM
Tags
applications, camaro, filter, fit, fram, good, lt1, m1111, m1202, m1302, mobil, mobile, mobiloil, oil, quarts, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
