Finally did a complete tune-up, Doh!
Finally did a complete plug change, oil & filter, Bosch O2's, and hooked up my MSD DIS-4 ignition (had to send it in for a repair). I can't believe how much nastier this thing runs with just a simple tune-up. I've had a high RPM miss above 6,000 for awhile, but most of this I attributed to the MSD DIS-4 not being hooked up. The car really by mileage does not need a tune-up or so I thought, only put about 500 miles on the car since the last change, but that was almost 5 years ago I can't believe how bad my plugs looked, even my O2's were just black as charcoal! I installed a set of NGK TR55 (.055 pre-gap, checked), Mobil 1 M1-111 shorty filter, pair of Bosch O2's, MCCC (mopar combustion chamber cleaner, including TB & intake), Mass air meter cleaner, and I re-installed the MSD DIS-4 ignition box (in conjuction with my Delteq setup).
Wow, what a difference! The car just gets it now, from a 3k roll in first the 315/30/18 BFG Drags get squirly..... The car actually pulled all the way to 6300 rpm's without a miss until the soft touch kicked in. It has not pulled past 6k without a miss in 1/2 a year or more (ever since I removed the MSD DIS-4). The car even idles much better now, it actually sounds like it has a baby LT4 hotcam even though its the stock 96 grind.
Just thought I would share my good experience with a simple LT1 tune-up. (Oh, I almost forgot, I still hate changing plugs on a LT1, but having a BMR k-member and longtubes makes the job so much simpler.)
You may want to reconsider using Bosch O2 sensors in the future. From what I can gather, they tend to suck. Most people would recommend sticking with AC/Delco O2's.
while the engine off or running ? you take off the intake and spray it thru the TB blade ? or thru some kind of hole on tb ? cause I cant find any vacumm hose attb for lt1 at all.
http://shbox.com/1/coil_testing.jpg
PS: Sorry for the hi-jack. Just trying to help
Glad you got it running good. Sometimes my car runs good, some days it feels kind of slow, but even on a good day I feel like it has never run completely right and I have a fresh motor and replaced nearly everything except the ICM (was tested). Some of you guys are lucky, I can't even put a decent cam in that passes smog, my pitiful cam barely passed.
