lt1 block?
lt1 block?
i just bought a z28 with high miles and was wondering if my 4bolt main block that i have built that came out of a mid 90's truck will work in place of the lt1 block? my plains are to buy bigger center bolt heads and keep the factory tb and intake setup. i basically want to know can i use my truck shortblock and bolt the factory lt1 top end on it?
the truck block should just bolt right in as far as motormount location and i know bellhousing will. Lt1 components no, but you could use any cmallblock stuff out there, you have alot more choices than if you went with lt1. Is it a vortec?
