LT1 1994 Z28 Runs a little hot, is this normal?
Idle the car will stay at 170ish
When I get the on highway the car will go all the way up the the middle of the gauge so im guessing thats 220?
City Driving its exactly 180 all the time
I have a hypertech 1008 160 degree thermostat also
Flushed out the hole entire system when I changed the Optispark
Do I have a bad waterpump or something? I Havent the slightest clue
My transmission was slipping also when it decided to run hot so after I get the tranny rebuilt im going to fix this
Is the tranny slipping and gone bad the reason the engine gets hot possibly?
I don't see what the problem is. 220 degrees is perfectly normal. The factory fans don't even come on until 227 degrees.
A thermostat alone won't have a significant effect on coolant temperatures at speed - you need it coupled with earlier fan programming to take full advantage.
I can see how this "could" happen. If the transmission is VERY hot the transmission fluid going through the radiator might be able to heat up the water/coolant. First place I'd look is the air dam.....that will for SURE make the car heat up when going down the road. I know first hand.
How much of the rad is the transmission cooler? The excess heat has to go somewhere, and the coolant is the closest somewhere. I think that about 220 is too much for going down the road, and the tranny slipping would cause more heat from the transmission.
220 is normal with ac on sitting in traffic. 195-200 is about right when going down the street, but once heat soak kicks in its hard to get the temps back down...
As for air in the system,this is possible. When I had air in my system the guage would go straight up every time I came to a stop,,then goes back to normal,,then back to hot,,etc.. Do you notice this?
