Injector confusion
Injector confusion
Long story short, I changed my clogged injectors and replaced them with the same oem injectors. Now the car idles at 500 rpms when I pull it out of gear but doesn't die. Tap the gas, it'll rev then idle at 900 like normal. Anyone have ideas as to why, or how to fix it?
+1 - CC503 + LE2 Heads = Why the heck? However, the problem probably lies with your IAC. Can you log the car with datamaster? It will help to see what the IAC counts are at and if your IAC motor is functioning. You might wanna try the reset procedure on your IAC to see if this helps.
