lt1 383
lt1 383
looking at buying this 383 on here:
383 LT1 Scat crank & rods, forged Probe -15cc pistons. 2bolt block. Has 6500 miles on it. Had the normal cleaning, decking, new frost plugs, etc. Clevite bearings throughout. Internally balanced and blueprinted.
and I was wondering what the best set of heads would work with the lt1 383? he said he ran le3's on it. But I was wondering what is the cheapest set of heads that i could go with? Looking to spend under 700 if possible...
That -15cc piston is going to give you about 10.5:1 compresion, which is low for a lt1..
You would want a -5cc piston to get it around 12:1.
you might be able to find some used LE or AI heads for around $700.
Isn't the stock compression on a lt1 10.5:1? Is that low of compression going to hurt anything?
the crank and pistons are forged
Would I hurt anything by running stock lt1 heads for a couple of months until I could save up more money and buy a new set of le2 heads/cam?
I know am I am going to loose horsepower but this car is going to be a weekend driver... I'd be happy If i could get 325hp out now until I can get the set up the way i want it with le2 heads/cam and eventually a turbo...
Sounds to me like you have alot of homework left to do. If you're planning on adding a turbo later, your shortblock needs to be built for it NOW. An engine isn't something you can "build as you go." The successful strong engines are built by people who research, do their homework, and build towards one goal. Research what these people have done.
My suggestion - be patient and do everything all at once. It makes way more sense in so many ways.
well i don't have the money for a turbo right now...
So could I get away with stock heads for a month or 2 until i could get a pair of le2 and a cam package? How much wld it affect my performance? I know its going to affect it im just trying to see how much...
thanks guys sry for the dumb questions
I know what your looking at, and I would suggest that if you already have a running engine in your car that you wait till you can save up and get a complementing top end to go with you END goals. like RamAir95 said ... do it once
Be patient and wait until you have the money to do everything at once.
well i don't have another engine and i really want to drive my camaro again! am i going to hurt anything driving it with stock heads for 2 months?? I think i've decided maybe to pass up on the turbo idea...
thanks guys
thanks guys
