impact of too short pushrods?
I'm starting to wonder if my pushrods are too short in my engine. Would that cause me to look like I'm losing power on top (past 5500 and look like valve float?)
I have some 7.05's right now and have some 7.2's on the shelf. I was thinking of swapping them out on the #1 cylinder only, using a permanent marker and seeing how it compared if I let the engine run for a few revolutions. is there an easy way to test this without pulling the intake and using a solid lifter? I have a comp cams pushrod checker available.
thoughts?
thoughts?
here's the valve tip with some sharpie testing real quick. this is with the 7.05...
i let it run for about 5-10 seconds so that that lifter would pump up
and here's the 7.2 pushrod...
here's the 7.05 from the side...
here's the 7.20 from the side...
notice how the 7.2 side shot looks like it hangs over the valve more toward the exhaust
if i recal, the 10308 (99893?)cranes they are 1.46 OD I think, i'd have to take it off and measure installed height. why do you ask about the installed height? coil bind?
they are setup for 180lbs on the seat according to the guy that did the heads.when I talked to him, he was pointing at the lifters instead of the springs.
Crane 10308 spring is :
1.75" install height
165 lb seat
426 open @ 1.10"
...so if they are 180 on the seat maybe installer shimed them to 1.7x to bump up seat preasure to 180??
GM846 cam should work well with the 10308 springs
My $02 on the PR length is 7.05 based on pics.
stock lifters @ 2500 miles should be fine
while valve springs could cause you to nose over at higher RPM's I would look into ignition.
even if the springs are installed at 1.70 you won't hit coil bind with the 846.
165 lb seat
426 open @ 1.10"
165 lb seat
426 open @ 1.10"
165 lb seat
426 open @ 1.10"
i'll take the spring off and measure to confirm. The guy that did the heads asked me to bring the springs by to test them out to see if they are still ok. I'm doing all this because of my other thread about the dyno tune and trying to address what is happening at 5500-6000 on my dyno chart. https://ls1tech.com/forums/lt1-lt4-m...-dynotune.html
Those are the springs that have been recommended to use for the GM847. I have a crane in that profile and those are what they suggested I use as well. Most SR spring pressures are over 200lbs on the seat.
Stay with what you have. The sweep looks fine. Notice on the 7.2 the roller tip is not making full contact onto the valve tip.
For the record i was running 7.2 pushrods with that cam and the same springs he is, but the installed height was around 1.8". My point was there is no way in hell he is getting valve float with that cam with 180# of seat pressure. Crane only calls for 125 for that cam jfyi.
