roller rocker ajustment
i have comp cam 7.195 push rods, stock new lifters, ebay 1.6 roller rockers self aligning, and comp cam beehive springs, and a lt4 hot cam i set them to 1/4 past zero lash and they where still loose i set them to 1/2 turn and then sounded like they where loose when the motor got up to temp i am already running 10w 40 oil ...so what im asking is how much is to much adjustment for the rockers. I don't want to set them to tight so where do i go from hear 3/4 turn or run thicker oil
they are stock new replacement lifters and yea its not the rocker noise im hearing...i guess ill try out the 3/4 past zero lash i just don't want to over do it and lose compression or hurt some thing else
and also when when im driving the car around 2300-2500rpm the car feels like its struggling and the exhaust starts popping not back firing but popping but at wot the car runs fine and after i got my new push rods in my speedo stopped working
